[OpenLayers-Dev] OL 2.8 RC
Björn Harrtell
bjorn.harrtell at gmail.com
Wed Apr 8 03:22:41 EDT 2009
Sounds good. I'd be happy to look at it. I've tried to setup examples
but they haven't worked correctly with previous attempts to implement
this, so chances for inclusion in 2.8 is now in my opinion low.
The best would be if you could attach it as a patch or complete js to
this ticket:
http://trac.openlayers.org/ticket/1967
But if that's a problem for you, you're welcome to send it anyway you like.
/Björn
On Wed, Apr 8, 2009 at 04:23, rc <rajchundur at gmail.com> wrote:
> Hi christopher,
> with regard to using arcmap cache, i combined the solutions posted by both matthew snape and m.priour and also had to set the ymin property to low Y of the data extent. I could then successfully use the arcmap cache both at 9.2 and 9.3 . I arrived at this solution through some trail and error but works for all subsequent cache i have created and it plays nicely with other openlayer tile sources.
> Would it help to post my modified js file?
> RC
> On Tue, Apr 07, 2009 at 12:47:19AM -0600, Tim Schaub wrote:
>> Hey Chris-
>> I know you have a couple things you'd still like to get in to 2.8. Bart
>> and I are still working on a cursor style patch as well - but I'm done
>> for the night.
>> Would Wednesday work for a release candidate? I will be available
>> tomorrow for additional reviews. Please assign to me or ping.
>> If not Wednesday, a couple hours heads up would be appreciated.
> So, there are two things on my plate that I care about:
> * ArcXML support, which I've been working on rewriting the patch for.
> The format works, but it is kind of a mess, and so I've been trying
> to make it less of one.
> * gridOrigin parameter support
> I would be willing to toss the latter if it weren't for the fact that it
> appears that no one can write an ArcGIS map cache reader without it;
> Matt says that 'everything is working fine', but no users have yet been
> able to set up the map cache.
> In any case, with the current state of the release, I'm not planning on
> forcing the issue; I'd like to see us get the remaining tickets handled
> *without* booting them to the next release. I'm willing to be patient on
> this if other people aren't wanting to force the issue: My deadlines are
> past now, and I realize that, but I don't want us to have a crappy
> release for the sake of arbitrary deadlines.
> Perhaps we can get together on Thursday afternoon and discuss what the
> current state is, and where we should go.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> View this message in context: http://n2.nabble.com/OL-2.8-RC-tp2597293p2602730.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
More information about the Dev
