[OpenLayers-Dev] [OpenLayers-Users] GetCapabilities proxy
problem.
Kwong Hu Kiu
kwonghu at hotmail.com
Sat Apr 25 08:41:36 EDT 2009
No one ever encountered the problem described below ?
Thanks
To: users at openlayers.org
Date: Sun, 19 Apr 2009 13:49:33 +0800
Subject: [OpenLayers-Users] GetCapabilities proxy problem.
I have this in the header of the xml file which I stream
to the browser whenever there is getcapabilities request.
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!-- The DTD (Document Type Definition) given here must correspond to the version number declared in the WMT_MS_Capabilities element below. -->
<!DOCTYPE WMT_MS_Capabilities SYSTEM
"http://www.digitalearth.gov/wmt/xml/capabilities_1_1_1.dtd"
<!-- Vendor-specific elements are defined here if needed. -->
<!-- If not needed, just leave this EMPTY declaration. Do not
delete the declaration entirely. -->
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
=============The company I am with are behind a proxy that
requires a username and password to access the internet.
What happens is that the browser and visual studio 2008 complain
that the remote server requires a proxy authentication to access
the DTD specified in the xml header.
At the moment I have removed the link above and it seems to work fine.
How should i fix it ?
Cheers.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090425/8c9bdecf/attachment.html
More information about the Dev
