[OpenLayers-Dev] Unhighlight feature + KEY_ESC : IE bug
Alexandre Dube
adube at mapgears.com
Mon Aug 3 08:58:34 EDT 2009
I made an example out of the select-feature.html example. I only
added a keyboard handler to the SelectFeature control and it still do
the problem. See the example (1).
I opened a ticket for this (2). Currently unassigned and without a patch.
Alexandre
(1)
http://dev4g.mapgears.com/openlayers/ie-highlight-bug/examples/select-feature-esc.html
(2) http://trac.openlayers.org/ticket/2214
Alexandre Dube wrote:
> Hi,
> I tried an other key (instead of 'esc') and the problem went away. So
> it really looks like a 'esc' key problem in IE. Can anyone comments
> about this, please ?
> Alexandre
>> Hi,
>> I have a very odd behavior with the SelectFeature control in IE +
>> keyboard handler using the KEY_ESC to unselect all features. I use a
>> customized DeleteFeature control, who is responsible to set the feature
>> "state" to delete and redrawing it. It has it's own SelectFeature
>> control for feature selection.
>> When unselecting by 'clicking out', it works fine. But when hitting
>> "esc", it DOES unselect all features + the unhighlight function is
>> called, but features stay the "selected" color.
>> I checked the select-feature example (1) and it doesn't have this
>> behavior, so it looks like a combination of ESC key problem +
>> SelectFeature Control... See a live example of the problem (using
>> trunk) (2).
>> I'm out of solution for this one. Any comments ?
>> (1) http://openlayers.org/dev/examples/select-feature.html
>> (2)
>> http://dev4g.mapgears.com/openlayers/ie-highlight-bug/examples/ie-highlight-bug.html
>> N.B. Problem viewed in IE7, don't know about other IE versions.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
