[OpenLayers-Dev] A kind of MultiLayer container
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Aug 4 12:57:46 EDT 2009
On Tuesday, August 4, 2009, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> On Tue, Aug 4, 2009 at 6:04 AM, Eric Lemoine<eric.lemoine at camptocamp.com> wrote:
>> On Monday, August 3, 2009, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>> Hi devs,
>>> I want to ask if anyone has made something like Vector/RootContainer,
>>> a layer that would contain several layers, and every layer would
>>> activate/deactivate on different zoomLevels.
>>> Simple case: 3 (or more) layers combined in one ContainerLayer
>>> small scale: WMS raster layer
>>> larger scales: other WMS raster layer
>>> large scale: WFS vector layer
>>> Usually I always register zoomend event on map, and manually activate
>>> or deactivate layers...but it got little bit boring to do that on
>>> application level every time.
>>> I remember Alexandre did something like that but for Vector layer
>>> or http://openlayers.org/pipermail/users/2009-January/009666.html
>>> Anyone did something like that? (does mapfish maybe has soemthing like that)
>>> If not, can anyone just give few tips, so I could start developing it...
>> Hi Ivan
>> Can't you just set different resolution ranges in the layers?
>> Cheers,
> Tnx for replies guys,
> Yes yes, im setting ranges for my layers, but I want to have only one
> layer shown in layerSwitcher for group of layers.
> I guess I just have to create one dummy layer with inLayerSwitcher:
> true, and other layers to false. And then just register activate,
> deactivate events that will turn off/on all group layers. (as alex
> suggested, tnx)
> I was just wondering if it would have sense to have it included in
> API, not to do it manually all the time...
Sorry I misunderstood you Ivan. IIRC we have that in the MapFish layer
tree, but I guess you don't want to pull the entire Ext lib just for
that.
> Cheers
>>> Tnx&Cheers,
>>> Ivan Grcic
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Dev mailing list
> Ivan Grcic
Eric Lemoine
More information about the Dev
