[OpenLayers-Dev] [ol 2.8] Altitude in KML file
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Sun Aug 9 15:19:06 EDT 2009
Did you check feature.attributes.altitude?
If not, can you provide a sample KML file?
Best regards,
Bart
Joel Tremblet wrote:
> Hello
> In kml file coordinates element have longitude, latitude and altitude
> I display the track on Openstreet map with openlayers and I want to display
> altitude of the nearest point when I click on the map
> I found longitude and latitude in feature.geometry.coordinate but altitude
> is nowhere
> Where can I find altitude ?
> Thanks
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev
