[OpenLayers-Dev] Fwd: Help to create FeatureId filter & OpenLayers.Filter.Logical.NOT
Ivan Grcic ivan.grcic at geofoto.hr
Thu Dec 10 12:38:13 EST 2009
Hi devs,
before opening ticket i want to confirm that im right about this issue
Currently its not possible to make filter like this:
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<And>
<Not><ogc:FeatureId fid="Feature.1"/></Not>
<Not><ogc:FeatureId fid="Feature.2"/></Not>
</And>
</Filter>
I trace the source of it, in Format/Filter/v1.js writers&readers for
AND,OR, NOT do not handle FeatureIds seperatly as root "Filter" does.
line: 296
            "Not": function(filter) {
                var node = this.createElementNSPlus("ogc:Not");
                var childFilter = filter.filters[0];
                this.writeNode(
                    this.getFilterType(childFilter), childFilter, node
                return node;
That happens because FeatureId doesnt have type and getFilterType
method throws "Filter writing not supported for rule type: undefined"
if we try to encapsulate FeatureId with Logical.Not
Its neccesary to check if filter is of FeatureId type and treat it
differently, like the root Filter element does
                var sub = childFilter.CLASS_NAME.split(".").pop();
                if(sub === "FeatureId") {
                    for(var i=0; i<childFilter.fids.length; ++i) {
                        this.writeNode("FeatureId", childFilter.fids[i], node);
                } else {
                    this.writeNode(
                return node;
Please can anyone confirm this?
Tnx
---------- Forwarded message ----------
Date: Thu, Dec 10, 2009 at 2:10 PM
Subject: Help to create FeatureId filter & OpenLayers.Filter.Logical.NOT
To: users at openlayers.org
I need to make a filter that combines Layers.Filter.Logical.NOT with FeatureId.
Filter structure  should  be like:
<And>
</And>
</Not>
</ogc:Filter>
I tried creating one like this:
var filter_1_1 = new OpenLayers.Format.Filter({version: "1.1.0"});
var xml = new OpenLayers.Format.XML();
var featIdsFilter = [];
//iterate trough features and make  arrays of <Not><ogc:FeatureId
fid="Feature.1"/></Not> filters
for(var i=0, len=wfsLayer.features.length; i<len; i++){
   featIdsFilter.push(
       new OpenLayers.Filter.Logical({
           type: OpenLayers.Filter.Logical.NOT,
           filters: [new OpenLayers.Filter.FeatureId({fids:
[wfsLayer.features[i].fid]})]
//combines previous array with AND filter
var filterObj = new OpenLayers.Filter.Logical({
   type: OpenLayers.Filter.Logical.AND,
   filters: featIdsFilter
try{
   var filter = xml.write(filter_1_1.write(filterObj));
} catch(err) {
   alert(err);
filterObj gets created but when I try to write filter I get error:
I used FIlters a lot before but for some reason I cant make Logical.NOT to work.
Apparently im not using OpenLayers.Filter.Logical.NOT in the right way...
Anybody had case like this?
Thanx,
Cheers
Ivan Grcic
Ivan Grcic
More information about the Dev mailing list
