[OpenLayers-Dev] possible bug in OpenLayers.Renderer.VML
Jachym Cepicky jachym at bnhelp.cz
Tue Dec 15 06:11:38 EST 2009
I have implamented  possibility to digitize holes into existing polygons (donuts),
and it seems to be working well:
http://dev.openlayers.org/sandbox/jachym/donuts2/examples/editingtoolbar.html
howto:
1) draw polygon
2) draw 'hole' into it
It works in Firefox and Opera and kind-of-works in IE.
In IE, you draw the polygon and when you try to draw the hole, the
polygon jumps from the original location (the difference and direction
corresponds with the difference between first point of polygon and first
point of hole). Than it moves around the map, while you are dragging the
mouse. When you finish the hole, it jumps back and everything
looks fine again.
Is it possible, that there is bug in OpenLayers.Renderer.VML? I was not
able to trek down the code.
Thanks
Jachym
Jachym Cepicky
e-mail: jachym bnhelp cz
URL: http://bnhelp.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299  ED8A C8AB 74B8 08D4 E08F
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20091215/1d6d4d12/attachment.bin
More information about the Dev mailing list
