[OpenLayers-Dev] responseText from GetFeature (WFS POST) empty
with OL2.7 + Geoserver 1.7.2
Tim Schaub
tschaub at opengeo.org
Tue Feb 3 16:38:28 EST 2009
Hey-
Is this on IE?
If so, can you check whether the response has an
xmlns:xml="http://www.w3.org/XML/1998/namespace" attribute at the root?
Tim
T. Vieira wrote:
> Hi,
> I've been developing over OL2.7 and Geoserver 1.6.2 and when i execute a
> GetFeature (WFS POST), the response of it comes with this information:
> -> response.responseText:
> --> <?xml version=\"1.0\" encoding=\"UTF-8\"?><wfs:FeatureCollection
> numberOfFeatures=\"7\" timeStamp=\"2009-02-02T17:15:01.389Z\"
> xsi:schemaLocation=\"http://www.xlm.pt/cadrede_gis
> http://10.112.80.32:8080/Geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=.........
> etc;
> -> response.responseXML.text:
> --> 108130.789724504 -44078.85197682108130.789724504
> -44078.851976821413701060037331900-01-01ZAntiga E7108130.789724504
> -44078.8519768290#FF990011teste108130.789724504 -44078.85197682108152.9323
> .......... etc
> Parsing method:
> var doc = response.responseXML;
> if (!doc || response.fileType!="XML") {
> doc = OpenLayers.parseXMLString(response.responseText);
> ..and all works fine.
> I upgraded to Geoserver 1.7.2 and the result is:
> etc; (the same output as before)
> The parser fails. I can't get any information of the feature.
> The method "OpenLayers.parseXMLString(response.responseText);" is
> deprecated, so i tried with the new method (OpenLayers.Request.POST), but
> the responseXML.text field is still empty.
> Any idea what is wrong?
> Thanks in advanced.
> Tiago Vieira
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
