[OpenLayers-Dev] comment wrt latest GML update
Eric Lemoine eric.c2c at gmail.com
Wed Feb 4 15:36:33 EST 2009
On Wed, Feb 4, 2009 at 6:41 PM, Tim Schaub <tschaub at opengeo.org> wrote:
> I will argue against making things "consistent" by *not* making use of
> gml:boundedBy.
As Chris mentioned the rendering engine looks at the geometry bounds
to determine whether the feature is drawn or not:
    drawFeature: function(feature, style) {
         if(style == null) {
             style = feature.style;
         if (feature.geometry) {
             var bounds = feature.geometry.getBounds();
             if(bounds) {
                 if (!bounds.intersectsBounds(this.extent)) {
                     style = {display: "none"};
                 return this.drawGeometry(feature.geometry, style, feature.id);
So if the bounds received from the server aren't incorrect OpenLayers
may not draw the feature while the feature is in the current extent. I
tend to think that determining whether the feature should be drawn or
not is an internal thing that should be based on an internal
calculation.
Cheers,
Eric
More information about the Dev mailing list
