[OpenLayers-Dev] Destroying popups with abandon
Paul Dziemiela
paul at dziemiela.com
Wed Feb 4 20:16:40 EST 2009
Here you go.
I am rather uncertain how you all work together so pardon my blundering
about.
http://trac.openlayers.org/ticket/1928
Cheers and Thanks,
Paul
Sent: Wednesday, February 04, 2009 7:02 PM
To: Paul Dziemiela
Cc: dev >> openlayers
Subject: Re: [OpenLayers-Dev] Destroying popups with abandon
This looks great, Paul. Can you make a ticket and patch for this? :-)
Erik
On Wed, Feb 4, 2009 at 15:41, Paul Dziemiela <paul at dziemiela.com> wrote:
Hello,
In some cases I need to "clear the decks" of popups and would like to simply
blast away with the destroy() function anywhere that feature.popup is not
null. However, when I try this against features that haven't actually
created a popup I get several errors. Is it reasonable to expect destroy()
to execute in any case without errors?
The following changes would be needed to destroy() in Framed.js
destroy: function() {
this.imageSrc = null;
this.imageSize = null;
this.isAlphaImage = null;
this.fixedRelativePosition = false;
this.positionBlocks = null;
//remove our blocks
// Added this test
if (this.blocks != null) {
for(var i = 0; i < this.blocks.length; i++) {
var block = this.blocks[i];
if (block.image) {
block.div.removeChild(block.image);
block.image = null;
if (block.div) {
this.groupDiv.removeChild(block.div);
block.div = null;
this.blocks = null;
OpenLayers.Popup.Anchored.prototype.destroy.apply(this, arguments);
And the following changes to destroy() in Popup.js
this.id = null;
this.lonlat = null;
this.size = null;
this.contentHTML = null;
this.backgroundColor = null;
this.opacity = null;
this.border = null;
if (this.events != null) {
this.events.destroy();
this.events = null;
if (this.closeDiv != null) {
OpenLayers.Event.stopObservingElement(this.closeDiv);
this.groupDiv.removeChild(this.closeDiv);
this.closeDiv = null;
if (this.div != null) {
this.div.removeChild(this.groupDiv);
this.groupDiv = null;
if (this.map != null) {
this.map.removePopup(this);
this.map = null;
this.div = null;
this.autoSize = null;
this.minSize = null;
this.maxSize = null;
this.padding = null;
this.panMapIfOutOfView = null;
Thanks!
Paul
Dev mailing list
Dev at openlayers.org
http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090204/58868e6e/attachment.html
More information about the Dev
