[OpenLayers-Dev] responseText from GetFeature (WFS POST) empty
with OL2.7 + Geoserver 1.7.2
T. Vieira
tvieira at xlm.pt
Thu Feb 5 05:11:07 EST 2009
Hi Tim,
I tested it. When i remove xmlns:xml="http://www.w3.org/XML/1998/namespace"
from response, it returns the feature on the map.
I'll be waiting for your workaround or any patch to solve this issue.
Thanks,
Tiago Vieira
Tim Schaub wrote:
> Hey-
> T. Vieira wrote:
>> Hi,
>> the response contains:
>> xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"
>> xmlns:xml=\"http://www.w3.org/XML/1998/namespace\"
>> xmlns:sf=\"http://www.openplans.org/spearfish\"
>> xmlns:ows=\"http://www.opengis.net/ows\"
>> xmlns:gml=\"http://www.opengis.net/gml\"
>> xmlns:xlink=\"http://www.w3.org/1999/xlink\">
> My understanding is that this is a foggy area of the XML spec. The most
> recent spec says the xml namespace is implicitly declared - previously,
> nothing was said. Some parsers do not do well with this attribute
> (xmlns:xml). IE's parser is among them.
> This attribute is new in GeoServer 1.7.2. I've opened an issue there:
> http://jira.codehaus.org/browse/GEOS-2606
> I'll see if we can come up with a workaround on our end.
> Tim
>> Tiago Vieira
>> Tim Schaub wrote:
>>> Hey-
>>> Is this on IE?
>>> If so, can you check whether the response has an
>>> xmlns:xml="http://www.w3.org/XML/1998/namespace" attribute at the root?
>>> Tim
>>> T. Vieira wrote:
>>>> Hi,
>>>> I've been developing over OL2.7 and Geoserver 1.6.2 and when i execute
>>>> a
>>>> GetFeature (WFS POST), the response of it comes with this information:
>>>> -> response.responseText:
>>>> --> <?xml version=\"1.0\" encoding=\"UTF-8\"?><wfs:FeatureCollection
>>>> numberOfFeatures=\"7\" timeStamp=\"2009-02-02T17:15:01.389Z\"
>>>> xsi:schemaLocation=\"http://www.xlm.pt/cadrede_gis
>>>> http://10.112.80.32:8080/Geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=.........
>>>> etc;
>>>> -> response.responseXML.text:
>>>> --> 108130.789724504 -44078.85197682108130.789724504
>>>> -44078.851976821413701060037331900-01-01ZAntiga E7108130.789724504
>>>> -44078.8519768290#FF990011teste108130.789724504
>>>> -44078.85197682108152.9323
>>>> .......... etc
>>>> Parsing method:
>>>> var doc = response.responseXML;
>>>> if (!doc || response.fileType!="XML") {
>>>> doc = OpenLayers.parseXMLString(response.responseText);
>>>> ..and all works fine.
>>>> I upgraded to Geoserver 1.7.2 and the result is:
>>>> etc; (the same output as before)
>>>> The parser fails. I can't get any information of the feature.
>>>> The method "OpenLayers.parseXMLString(response.responseText);" is
>>>> deprecated, so i tried with the new method (OpenLayers.Request.POST),
>>>> but
>>>> the responseXML.text field is still empty.
>>>> Any idea what is wrong?
>>>> Thanks in advanced.
>>>> Tiago Vieira
>>> Tim Schaub
>>> OpenGeo - http://opengeo.org
>>> Expert service straight from the developers.
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> Dev mailing list
View this message in context: http://n2.nabble.com/responseText-from-GetFeature-%28WFS-POST%29-empty-with-OL2.7-%2B-Geoserver-1.7.2-tp2265638p2274119.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
