[OpenLayers-Dev] Split polygon
Ivan Grcic
igrcic at gmail.com
Fri Feb 13 11:44:39 EST 2009
Hi, you can check this links :
http://www.nabble.com/OL-Based-GeoEditor-tp17818464p20741443.html
https://143.93.78.98/geoEditor2/editor.html (name/pass: demo/empty)
http://crschmidt.net/mapping/wpserverdemo/
But anways, it is server side that does the thing, openlayers only
send and recieves data... (as far as i know)
Regards,
On Fri, Feb 13, 2009 at 5:14 PM, Aurélien Pelletier
<aurelien.pelletier at atosorigin.com> wrote:
> Hello,
> I'd like to have an idea of how hard it would be to implement the "split
> polygon" feature in openLayer as it is done in geomajas:
> http://www.geomajas.org/majas-tutorial/applications/tutorial/html/sample-editing.html
> The polygon and the line are send to the server, the polygon is splitted
> using the JTS library on the server side and send back to the client.
> Thanks
> Aurélien
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Ivan Grcic
More information about the Dev
