[OpenLayers-Dev] my first control... again
toni hernández
tonidelacalle at gmail.com
Thu Feb 26 02:59:40 EST 2009
Ok.
I found the solution.
My mistake.
I forgot to include this the firebug.js file
<script src="../lib/Firebug/firebug.js"></script>
On Wed, Feb 25, 2009 at 10:00 AM, toni hernández <tonidelacalle at gmail.com>wrote:
> can't manage my first control
> hi,
> I am still trying to develop a new control for my application. The control
> is called ParallelLine. I am sorry to bother you with this again.
> I copied most of the code from ModifyFeature control as Ivan suggested.
> As in the ModifyFeature control, this new control includes a selectControl
> variable.
> The problem is that when I activate my control the selectControl variables
> seems not to be propperly initialized.
> To test it, I added an alert to the SelectFeature activate method to see
> if it is called when instanciating the selectControl variable of my new
> control. And it isn't. I have tried to see what happen when I activate the
> original ModifyFeature, and of course, it works fine.
> I think I have forgotten to change some url. Otherwise I do not have any
> idea what is going on.
> I must have you all quite confused.
> This is how I call the js files.
> <script src="../OpenLayers.js"></script>
> <script src="../lib/OpenLayers/Control/ParallelLine.js"></script>
> This is how I initialize the parallelLine control
> initialize: function(layer, options) {
> this.layer = layer;
> OpenLayers.Control.prototype.initialize.apply(this, [options]);
> var control = this;
> var selectOptions = {
> geometryTypes: this.geometryTypes,
> hover: true,
> clickout: this.clickout,
> toggle: this.toggle
> this.selectControl = new OpenLayers.Control.SelectFeature(
> this.layer, selectOptions
> this.layer.events.on({
> "beforefeatureselected": this.beforeSelectFeature,
> "selectFeature": this.selectFeature,
> scope: this
> // Regiter the events (sigte)
> this.layer.events.register("mousemove", this, this.mmove );
> this.layer.events.register("mousedown", this, this.mdown );
> This is how I activate the parallelLine control.
> activate: function() {
> //this function is called. Sure.
> return (this.selectControl.activate() &&
> OpenLayers.Control.prototype.activate.apply(this,
> arguments));
> This is the activate method from SelectFeature.js which seems to be never
> called.
> /*From SelectFeature.js*/
> activate: function () {
> alert("yes");
> if (!this.active) {
> this.handlers.feature.activate();
> if(this.box && this.handlers.box) {
> this.handlers.box.activate();
> return OpenLayers.Control.prototype.activate.apply(
> this, arguments
> I promise not to bother you again in one week.
> ok two weeks then.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090226/1f21c431/attachment.html
More information about the Dev
