[OpenLayers-Dev] Game development problem - speed with lot of objects
Jachym Cepicky jachym.cepicky at gmail.com
Fri Jan 9 01:46:21 EST 2009
as mentioned earlier, OpenLayers.Layer.Markers should work for you
better (see http://openlayers.org/dev/examples/markers.html for
example).
If you decide to try custom mapserver layer, maybe you could have a
look at GeoServer [1] as well. It's configuration is GUI-based (in
contradistinction to MapServer [2]).
And to make it even more complicated, maybe storing the data into
PostGIS[3] database could simplify (at the end) some things as well.
Jachym
[1] http://geoserver.org
[2] http://mapserver.gis.umn.edu
[3] http://postgis.org
2009/1/8 Abuki <abuki at argo.in>:
> Hello,
> I´m not expert on OpenLayers and also English (I´m from Czech).
> I´m just trying to make my own browser-based game and I want to use
> OpenLayers for world map.
> Now the problem:
> I want to put on the base layer some object (coordinates from mysql)
> represented by png images (eg house) and I do it like this: make polygons
> (circles), make features and make featureLayer (I dont want use markers,
> because I would like have the clickable area not always square). Then add
> control onmouseclick, so i have clickable object - thats ok. But I dont know
> how to put there a lot of images, the only way I understand is to make image
> layer for every single PNG image, its ok BUT: When I put in mysql 1000
> objects a make this for all of them, it is slow (it takes about 10sec
> loading and browsing is not smooth), and i´m afraid that this is simple so
> what if would come something complicated...
> I dont uderstand mapservers and i want to find the way to not use them,
> because i will run the game on hosted site, so I cant install it there. Also
> when I try only vector or images layer alone it was slow.
> So could anyone help me to get it work faster? And is it possible without
> mapserver?
> Thanks
> Abuki
> View this message in context: http://n2.nabble.com/Game-development-problem---speed-with-lot-of-objects-tp2129189p2129189.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
More information about the Dev mailing list
