[OpenLayers-Dev] protocol.WFS and HTTP GET
Robert Sanson
SansonR at asurequality.com
Sun Jan 11 20:36:14 EST 2009
I was using POST for a lot of my communications between OL and a ColdFusion server, but discovered that POST requests seemed to hit a limit on the length of the URL, whereas the GET was more tolerant. Here is an example that failed with a POST, but succeeded with a GET:
var mgatexy = "http://web-cf8dev.agriquality.co.nz/agribasemapdata/indexpage.cfm?mode=maingate&farmid=" + farmid + "&easting=" + easting + "&northing=" + northing + "&lat=" + latitude + "&long=" + longitude;
var request = OpenLayers.Request.GET({
url: mgatexy,
callback: setHTML3
Robert Sanson
>>> <bartvde at osgis.nl> 10/01/2009 1:03 a.m. >>>
Hey Tim,
it just came to my mind since I wanted to port all of my application's WFS
requests to use Protocol.WFS. I use quite a bit of GET requests where POST
is not needed.
But you're right, why not use POST all the time.
Best regards,
Bart
> Hey-
> bartvde at osgis.nl wrote:
>> Hi list,
>> are there any plans to support HTTP GET in Protocol.WFS?
> It would be nice to have a property that let you decide if you always
> wanted GET. The drawback, of course, is when you've got a filter that
> serializes (+ rest of url) to 2083 chars.
> We're you envisioning a property, or some logic that tried to determine
> if POST was necessary?
> Also, it's probably worth asking why it makes a difference (aside from
> being gross that we have to POST GetFeature).
> Tim
>> Best regards,
>> Bart
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
Dev mailing list
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090112/f21f21c8/attachment.html
More information about the Dev
