[OpenLayers-Dev] occasional alpha hack error with FF 3
Zac Spitzer
zac.spitzer at gmail.com
Mon Jan 12 08:20:20 EST 2009
this code for detecting IE is throwing warnings in firebug
OpenLayers.Util.alphaHack = function() {
if (OpenLayers.Util.alphaHackNeeded == null) {
var arVersion = navigator.appVersion.split("MSIE");
var version = parseFloat(arVersion[1]);
Unexpected value undefined parsing r attribute.
[Break on this error] undefined
Util.js (line 414)
(my line numbers are a bit out as i have the $ stuff commented out as
I found IE gets
confused with jquery)
shouldn't there be a be a check to see if the array has two elements
before checking it?
logically
if(arVersion.length === 1)
OpenLayers.Util.alphaHackNeeded= false;
z
z
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the Dev
