[OpenLayers-Dev] What if I extend the OpenLayers.Style class??
Tim Schaub tschaub at opengeo.org
Wed Jan 21 04:58:58 EST 2009
Hey-
Milan Antonovic wrote:
> Thanks for your help,
> My idea was just to group many rule in a specialized class, so I don't
> need to put all the code in the initialization script of the map, but in
> a separate file.
Are you modifying each style instance?
If not, why not just have one?
Tim
> So in the initialization of the map I just write:
> var sRain = new OpenLayers.Style.Rain();
>     var pioggia = new OpenLayers.Layer.PySOS(
>         'rain',
>         SOS_url,
>             'offering': 'weather',
>             'eventTime': sTime.toTimestamp(4)+'/'+eTime.toTimestamp(4),
>             'observedProperty': ['rain']
>             eventTime: new Date(),
>             formatOptions: {
>                 internalProjection: pro,
>                 externalProjection: dis
>             styleMap: new OpenLayers.StyleMap(sRain)
> Here is my OpenLayers.Style.Rain code:
> OpenLayers.Style.Rain = OpenLayers.Class(OpenLayers.Style,{
>     sunny: "images/marker/sunny.png",
>     cloudy: "images/marker/cloudy.png",
>     rainy: "images/marker/rainy.png",
>     none: "images/marker/none.png",
>     graphicWidth: 40,
>     graphicHeight: 40,
>     graphicOpacity: 1,
>     initialize: function() {
>         this.rules = [];
>         this.setDefaultStyle(OpenLayers.Feature.Vector.style["default"]);
>         var noData = new OpenLayers.Rule(
>                 filter: new OpenLayers.Filter.Logical(
>                         type: OpenLayers.Filter.Logical.OR,
>                         filters: [
>                             new OpenLayers.Filter.Comparison(
>                                     type:
> OpenLayers.Filter.Comparison.LESS_THAN,
>                                     property: "eventTime",
>                                     value: "beginPosition",
>                                     binaryCompare: function(context,
> eventTime, beginPosition) {
>                                         var et = new
> Date((context[eventTime]).getTime());
>                                         var bp = new
> Date((context[beginPosition]).getTime());
>                                         return et < bp;
>                                     type:
> OpenLayers.Filter.Comparison.GREATER_THAN,
>                                     value: "endPosition",
> eventTime, endPosition) {
>                                         var et = new
>                                         var ep = new
> Date((context[endPosition]).getTime());
>                                         return et > ep;
>                 symbolizer: {
>                     graphicWidth: 15,
>                     graphicHeight: 15,
>                     graphicOpacity: this.graphicOpacity,
>                     externalGraphic: this.none
>         var ruleSunny = new OpenLayers.Rule(
>                         type: OpenLayers.Filter.Logical.AND,
>                         filters: [
>                                     type:
> OpenLayers.Filter.Comparison.EQUAL_TO,
>                                     property: "sum",
>                                     value: 0
>                                     type:
>                                     property: "measure",
>                                     value: "-"
>                 symbolizer: {
>                     graphicWidth: this.graphicWidth,
>                     graphicHeight: this.graphicHeight,
>                     externalGraphic: this.sunny
>         var ruleSunny2 = new OpenLayers.Rule(
>                         filters: [
>                                     type:
>                                     property: "sum",
>                                     value: 0
>                                     type:
>                                     value: 0
>                 symbolizer: {
>         var ruleCloudy = new OpenLayers.Rule(
>                         filters: [
>                                     type:
>                                     property: "sum",
>                                     value: 0
>                                     type:
>                                     value: 0
>                 symbolizer: {
>                     externalGraphic: this.cloudy
>         var ruleCloudy2 = new OpenLayers.Rule(
>                         filters: [
>                                     type:
>                                     property: "sum",
>                                     value: 0
>                                     type:
>                                     value: "-"
>                 symbolizer: {
>         var ruleRainy = new OpenLayers.Rule(
>                         filters: [
>                                     type:
>                                     property: "sum",
>                                     value: 0
>                                     type:
>                                     value: 0
>                 symbolizer: {
>                     externalGraphic: this.rainy
> this.addRules([ruleSunny,ruleSunny2,ruleCloudy,ruleCloudy2,ruleRainy,noData]);
>     CLASS_NAME: "OpenLayers.Style.Rain"
> 2009/1/21 Tim Schaub <tschaub at opengeo.org <mailto:tschaub at opengeo.org>>
>     Hey-
>     bartvde at osgis.nl <mailto:bartvde at osgis.nl> wrote:
>      > Hi,
>      > see also:
>      > http://trac.openlayers.org/ticket/1802
>      > Best regards,
>      > Bart
>      >> Hi all,
>      >> In my OL app, I needed to create some OpenLayers.Style class to
>     group
>      >> complex layer styling.
>      >> I create some classes like OpenLayers.Style.Rain,
>      >> OpenLayers.Style.Temperature to represent some
>      >> weather icons depending on some feature's attribute values.
>     Yes, you'll get good behavior with instanceof after r8445.  However, I
>     think you may be going about this the wrong way.
>     You shouldn't need to extend the Style class.  Instead you create a
>     Style object with rules that determine the styling for your
>     particular case.
>     e.g. something like:
>     var rainStyle = new OpenLayers.Style();
>     rainStyle.addRules([
>         new OpenLayers.Rule({
>             filter: new OpenLayers.Filter.Comparison({
>                 type: OpenLayers.Filter.Comparison.EQUAL_TO,
>                 property: "rain"
>                 value: "lots"
>             symbolizer: {
>                 externalGraphic: "wet.png"
>     You can also use the addUniqueValueRules convenience method on your
>     StyleMap [1].  Or check out the other style examples for inspiration
>     [2].
>     Tim
>     [1] http://openlayers.org/dev/examples/styles-unique.html
>     [2] http://openlayers.org/dev/examples/?q=style
>      >> But, I had an other problem, in the OpenLayers.StyleMap class
>     passed to my
>      >> weather layer.
>      >> I found this code in the initialize function:
>      >> *if(style instanceof OpenLayers.Style)*
>      >> This code block my Rain or Temperature classes to go further.
>      >> So I changed the code in something like:
>      >> *if(style instanceof OpenLayers.Style ||
>      >>                (style.CLASS_NAME &&
>      >> style.CLASS_NAME.indexOf("OpenLayers.Style")!=-1))*
>      >> Does it make sense to you?
>      >> Thanks
>      >>   Milan Antonovic
>      >> Milan Antonovic
>      >> Institute of Earth Sciences
>      >> University of Applied Sciences of the South Switzerland - SUPSI
>      >> Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
>      >> Tel: +41(0)58 666 62 13
>      >> E-mail: milan.antonovic at supsi.ch
>      >> Web: http://www.ist.supsi.ch
>      >> _______________________________________________
>      >> Dev mailing list
>      >> Dev at openlayers.org <mailto:Dev at openlayers.org>
>      >> http://openlayers.org/mailman/listinfo/dev
>      > Dev mailing list
>     Tim Schaub
>     OpenGeo - http://opengeo.org
>     Expert service straight from the developers.
>     Dev mailing list
Tim Schaub
More information about the Dev mailing list
