[OpenLayers-Dev] multipleSelectFeature on one layer
Alexandre Dube
adube at mapgears.com
Fri Jan 23 13:40:12 EST 2009
Hi devs,
I would like to propose some changes about the SelectFeature control.
First, I'll introduce what I want to do : I want to change the color
of a feature while the mouse is over it without selecting it. I managed
to do this by building a customized control similar to the SelectFeature
control named HighlightFeature. I shared the code and some people
showed interest in this feature. In fact, it was a good enough to be
added to trunk but there was a problem : it's too similar to the
My first new option was to modify the SelectFeature control to be able
to select and highlight. That's what I did, but I hit a wall : I needed
to add more new events "beforefeaturehighlighted", "featurehighlighted",
etc. a new array of highlightedFeatures, etc... That also became a
pain because it was yet an other duplication of something already
existant ( similair "select" feature events, an array of selected
features, etc....)
SO, that brings me to this solution, the first one Eric Lemoine
proposed : an array of selectedFeatures and select events for the
control ( without removing the ones of the layer ). Doing that, one
vector layer could have multiple select feature controls that would know
which feature it has selected, they could all have a different
renderIntent value ( this is already possible ) or their own style.
Then, the user could interact directly with the desired control's
selectedFeatures.
My example : One SelectFeature that select on click, has the default
render intent "select", on which I register a "featureselected" to
display a form to fill. And one other SelectFeature that select on
hover, has a custom render intent "temporary" to have a different color
and an event registered to "featureselected" to display a quick popup of
the infos of the hovered feature.
Even my DeleteFeature control I created a couple of weeks ago could
work by using an other SelectFeature control and using its own
featureSelected array.
I'll make thoses small changes, an example and propose this as an
enhancement. What do you think ?
Regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
