[OpenLayers-Dev] multipleSelectFeature on one layer
Alexandre Dube adube at mapgears.com
Mon Jan 26 08:34:00 EST 2009
Hi Eric,
  You're right.  So instead of removing the last renderIntent from the
stack, we need to remove the last renderIntent of the current SelectFeature.
  SFC = SelectFeature Control
  RIA = renderIntents array
  Let's say the mouse goes hover a feature and get selected by a 1st SFC :
  RIA : ["temporary"]
  Then the user click it to select it with an other SFC :
  RIA : ["temporary", "select"]
  Then the mouse goes out of the feature, unselecting it from the 1st SFC :
  RIA : ["select"]
  The feature is still drawn with the "select" renderIntent.  What do
you think ?  With this, you don't need to have 4 different
possibilities.  The user can define an infinite number of different
renderIntents, have a styleMap defining each one of them.
Alexandre
Eric Lemoine wrote:
> Hi Alex
> Consider this sequence: mouse goes over feature, feature is clicked
> (for selection), and clicked again (for unselection). With your "stack
> of intents" logic, the feature isn't redrawn as a result of the second
> click; instead it should be redrawn with the hover control's render
> intent, shouldn't it?
> Eric
> 2009/1/23, Alexandre Dube <adube at mapgears.com>:
>> Hi devs,
>>   Eric was right :
>> A first note. The current select feature implementation should
>> accomodate this use case: two controls on the same layer, one working
>> on click and the other on hover, only one of them actually changing
>> the feature style. This is achievable by registering a
>> beforefeatureselected listener, and have this listener return false.
>> Adding beforefeatureunselected might help fully accomodate that use
>> case.
>> Now if we want the two controls to do feature styling, we need the
>> stuff I mentioned previously - per-control selectedFeatures arrays and
>> events. But this is unfortunately not sufficient. Use case: two
>> controls, one working on click and the other on hover, both doing
>> feature styling but with different render intents. If we have this
>> sequence "mouse goes over feature, mouse clicks feature, mouse goes
>> out of feature", then the feature ends up being rendered with the
>> "default" render intent, while it's still selected from the click
>> control's perspective. In most cases, this isn't desirable I think.
>> At this point I don't have a solution to the above issue.
>> An idea that could resolve this issue : features could have a stack of
>> renderIntent instead of a normal string value.  Instead of assigning new
>> renderIntent value, it would stack in renderIntents array.  Instead of
>> reseting to "default", it would remove the last renderIntent in the
>> stack.  When the stack is empty, the "default" renderIntent is applied.
>>   That could work.  I'll try this and come back with more details.
>> Alexandre
>> Alexandre Dube wrote:
>>> Hi devs,
>>>   I would like to propose some changes about the SelectFeature control.
>>>   First, I'll introduce what I want to do : I want to change the color
>>> of a feature while the mouse is over it without selecting it.  I managed
>>> to do this by building a customized control similar to the SelectFeature
>>> control named HighlightFeature.  I shared the code and some people
>>> showed interest in this feature.  In fact, it was a good enough to be
>>> added to trunk but there was a problem : it's too similar to the
>>>   My first new option was to modify the SelectFeature control to be able
>>> to select and highlight.  That's what I did, but I hit a wall : I needed
>>> to add more new events "beforefeaturehighlighted", "featurehighlighted",
>>> etc.  a new array of highlightedFeatures, etc...  That also became a
>>> pain because it was yet an other duplication of something already
>>> existant ( similair "select" feature events, an array of selected
>>> features, etc....)
>>>   SO, that brings me to this solution, the first one Eric Lemoine
>>> proposed : an array of selectedFeatures and select events for the
>>> control ( without removing the ones of the layer ).  Doing that, one
>>> vector layer could have multiple select feature controls that would know
>>> which feature it has selected, they could all have a different
>>> renderIntent value ( this is already possible ) or their own style.
>>> Then, the user could interact directly with the desired control's
>>> selectedFeatures.
>>>   My example : One SelectFeature that select on click, has the default
>>> render intent "select", on which I register a "featureselected" to
>>> display a form to fill.  And one other SelectFeature that select on
>>> hover, has a custom render intent "temporary" to have a different color
>>> and an event registered to "featureselected" to display a quick popup of
>>> the infos of the hovered feature.
>>>   Even my DeleteFeature control I created a couple of weeks ago could
>>> work by using an other SelectFeature control and using its own
>>> featureSelected array.
>>>   I'll make thoses small changes, an example and propose this as an
>>> enhancement.  What do you think ?
>>>   Regards,
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
