[OpenLayers-Dev] New DragFeature Control and
SelectFeatureControl cross layers. Want to share
Andre Pereira de Matos
andre.matos at co.sapo.pt
Mon Jan 26 10:49:59 EST 2009
I didn't have a patch. The only thing I have is a new handler and a new control.
I can send you that code, if you want and you can include and test it.
Thanks,
André Matos
http://maps.sapo.pt
-----Original Message-----
From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On Behalf Of Joel Tremblet
Sent: sábado, 24 de Janeiro de 2009 21:00
To: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] New DragFeature Control and SelectFeatureControl cross layers. Want to share
I'm interested to test your code to select a layer.GML witch contain markers.
I have 2 layers of markers but only one layer can be selected by
[CODE]
selectControl = new OpenLayers.Control.SelectFeature(map.layers[1],
{onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});
{/CODE]
In which folder I must to download your patch
Thanks
Andre Pereira de Matos wrote:
> Forgot the code, sorry.
> Best Regards,
> André Matos
> http://maps.sapo.pt
> From: Andre Pereira de Matos
> Sent: sexta-feira, 16 de Janeiro de 2009 11:02
> To: 'Andreas Hocevar'
> Cc: dev at openlayers.org; users at openlayers.org
> Subject: RE: [OpenLayers-Dev] New DragFeature Control and
> Hi,
> I sent the code and a short explanation to OpenLayers dev and users...
> I didn't see your code yet... But I promise that I will.
> Thanks for sharing ;)
> Here is the mail, that I sent:
> I have done controls and handlers to handle events in features that are in
> different layers (with OpenLayers controls you only can handle events in a
> single layer, and that layer must be on the top), and as I received on
> mail requests to share my code, I decided to send it for the list. With an
> explanation how it works.
> Actually I made two controls, FeatureEventHandlerControl and
> DragFeatureControl and an handler (FeatureHandler) to help the
> FeatureEventHandlerControl.
> This two controls works pretty like the SelectFeature and DragFeature
> OpenLayers controls, but they work cross layers. They don't care about the
> layers. When you want to get an event from a feature, you must register
> that feature on the control, and when that event occurres you will be
> notified.
> For example:
> Var dragControl = new Sapo.Control.DragFeatureControl([], {
> 'dragstart': { callback: function(feacture, pixel){/*do something*/}
> context: this}
> 'drag': {
> callback: function(feacture, pixel){/*do something*/} context: this}
> 'dragend': { callback: function(feacture, pixel){/*do something*/}
> context: this}
> Var featureEvtHandler = new Sapo.Control.FeatureEventHandlers([], {
> 'click': { callback: function(feacture, pixel){/*do something*/} context:
> this}
> 'mouseover': { callback: function(feacture, pixel){/*do something*/}
> context: this}
> 'mouseout': { callback: function(feacture, pixel){/*do something*/}
> context: this}
> Map.addControl(dragControl);
> Map.addControl(featureEvtHandler);
> dragControl.activate();
> featureEvtHandler.activate();
> Var layer1 = new OpenLayers.Layer.Vector("Markers",
> projection: new
> OpenLayers.Projection("EPSG:4326"),
> styleMap: new
> OpenLayers.StyleMap({
> externalGraphic: "http://openlayers.org/dev/img/marker-gold.png",
> backgroundGraphic: "http://openlayers.org/dev/examples/marker_shadow.png",
> graphicYOffset:
> -20,
> backgroundXOffset: 0,
> backgroundYOffset: -17,
> pointRadius: 10
> Var layer2 = new OpenLayers.Layer.Vector("Markers 2",
> projection: new
> styleMap: new
> graphicYOffset:
> -20,
> pointRadius: 10
> Map.addLayer(layer1);
> Map.addLayer(layer2);
> Var feature1 = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Point(-1904105.3415234375, 4392319.753066596)); Var
> feature2 = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Point(-1504105.3415234375, 4392319.753066596));
> Layer1.addFeatures([feature1]);
> Layer2.addFeatures([feature2]);
> dragControl.addFeature(feature1);
> featureEvtHandler.addFeature(feature2);
> When occurs an event(dragstart, drag, dragend, click, mouseover, mouseout)
> in any of this features, in different layers, the callbacks will be
> notified.
> If you have any questions just ask us (André or João)!
> Regards,
> André Matos
> http://maps.sapo.pt
> From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On
> Behalf Of Andreas Hocevar
> Sent: quinta-feira, 15 de Janeiro de 2009 15:11
> To: Andre Pereira de Matos
> Hi Andre,
> 2009/1/13 Andre Pereira de Matos <andre.matos at co.sapo.pt>:
>> I have made a Project with openlayers, and at some point I had to make a
>> new
>> handler and a new control to provide draggable feature and handle events
>> like, click, mouseover, mouseout in features that was in different
>> layers.
>> The Openlayers control (DragFeature, SelectFeature) and handlers (Drag,
>> Feature) only works if the features are all in the same layer and the
>> layer
>> is on the top.
> I have no experience with the DragFeature control, but I have created
> a solution for feature selection that works with multiple layers
> recently [1]. An example is also avaialable [2].
> You may want to check this out, and I'd be interested to see your
> approach. Also, it would be cool to see if my approach also works with
> the DragFeature control.
> Regards,
> Andreas.
> [1] http://trac.openlayers.org/ticket/1666
> [2]
> http://dev.openlayers.org/sandbox/ahocevar/singleroot/openlayers/examples/select-feature-multilayer.html
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://n2.nabble.com/New-DragFeature-Control-and-SelectFeatureControl-cross-layers.-Want-to-share-tp2152758p2210540.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
Dev mailing list
Type: application/octet-stream
Desc: Controls.rar
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090126/c0c3c39c/Controls.obj
More information about the Dev
