[OpenLayers-Dev] multipleSelectFeature on one layer
Alexandre Dube
adube at mapgears.com
Mon Jan 26 11:20:48 EST 2009
Amos Hayes wrote:
> I think the big questions for me are:
> Where are you planning to store the states?
Do you mean feature.state ? I don't understand what you mean.
> How will an app developer obtain a list of currently selected features
> and distinguish between the 'selections' that have been applied if
> more than one control has been set up?
Since each SelectControl would have its own selectedFeatures array, you
can easilly access them with yourControl.selectedFeatures. By defining
each control a different renderIntent and having a renderIntents stack
array, you can easilly keep track of "by what control the feature was
selected".
I understand the fact that trying to have more than one SelectFeature at
a time is not very logic since one control == one type of action the
user wants to do, and normally the user wants to do 1 at a time, like :
- select features to delete them
- select a feature to modify its geometry then save
- select a feature to display its attributes values in a popup
Normally, only one of theses should be active at a time, except the last
one because it's only to display some info. The feature doesn't get
modified. So, it could be active at the same time as the other two,
with a hover:true option to display the popup when over a feature and
changing its color. Nothing more. What do you think ?
Alexandre
> Amos Hayes
> Geomatics and Cartographic Research Centre
> Carleton University
> ahayes at gcrc.carleton.ca
> +1.613.520.2600x8179
> On 26-Jan-09, at 10:13 AM, Alexandre Dube wrote:
>> Hi devs,
>> My only problem remaining : should the layer keep its selectedFeature
>> array ? If so, on selection, it's easy to know if a feature is already
>> selected. As soon as one control adds it to its own array, it checks in
>> the layer's one and add it if it's not there.
>> But for unselection, before removing it from the layer's array, we
>> would need to check all select features control and all controls
>> containing select features control. Since we can easily say that one
>> control does a specific task at a time, I don't really see the use of
>> the selectedFeatures array in the layer. I would just remove it and
>> avoid the above problem. What do you think ?
>> Alexandre
>>> Hi Eric,
>>> You're right. So instead of removing the last renderIntent from the
>>> stack, we need to remove the last renderIntent of the current
>>> SelectFeature.
>>> SFC = SelectFeature Control
>>> RIA = renderIntents array
>>> Let's say the mouse goes hover a feature and get selected by a 1st
>>> SFC :
>>> RIA : ["temporary"]
>>> Then the user click it to select it with an other SFC :
>>> RIA : ["temporary", "select"]
>>> Then the mouse goes out of the feature, unselecting it from the 1st
>>> SFC :
>>> RIA : ["select"]
>>> The feature is still drawn with the "select" renderIntent. What do
>>> you think ? With this, you don't need to have 4 different
>>> possibilities. The user can define an infinite number of different
>>> renderIntents, have a styleMap defining each one of them.
>>> Alexandre
>>> Eric Lemoine wrote:
>>>> Hi Alex
>>>> Consider this sequence: mouse goes over feature, feature is clicked
>>>> (for selection), and clicked again (for unselection). With your "stack
>>>> of intents" logic, the feature isn't redrawn as a result of the second
>>>> click; instead it should be redrawn with the hover control's render
>>>> intent, shouldn't it?
>>>> Eric
>>>> 2009/1/23, Alexandre Dube <adube at mapgears.com>:
>>>>> Hi devs,
>>>>> Eric was right :
>>>>> A first note. The current select feature implementation should
>>>>> accomodate this use case: two controls on the same layer, one working
>>>>> on click and the other on hover, only one of them actually changing
>>>>> the feature style. This is achievable by registering a
>>>>> beforefeatureselected listener, and have this listener return false.
>>>>> Adding beforefeatureunselected might help fully accomodate that use
>>>>> case.
>>>>> Now if we want the two controls to do feature styling, we need the
>>>>> stuff I mentioned previously - per-control selectedFeatures arrays
>>>>> and
>>>>> events. But this is unfortunately not sufficient. Use case: two
>>>>> controls, one working on click and the other on hover, both doing
>>>>> feature styling but with different render intents. If we have this
>>>>> sequence "mouse goes over feature, mouse clicks feature, mouse goes
>>>>> out of feature", then the feature ends up being rendered with the
>>>>> "default" render intent, while it's still selected from the click
>>>>> control's perspective. In most cases, this isn't desirable I think.
>>>>> At this point I don't have a solution to the above issue.
>>>>> An idea that could resolve this issue : features could have a
>>>>> stack of
>>>>> renderIntent instead of a normal string value. Instead of
>>>>> assigning new
>>>>> renderIntent value, it would stack in renderIntents array.
>>>>> Instead of
>>>>> reseting to "default", it would remove the last renderIntent in the
>>>>> stack. When the stack is empty, the "default" renderIntent is
>>>>> applied.
>>>>> That could work. I'll try this and come back with more details.
>>>>> Alexandre
>>>>>> Hi devs,
>>>>>> I would like to propose some changes about the SelectFeature
>>>>>> control.
>>>>>> First, I'll introduce what I want to do : I want to change the
>>>>>> color
>>>>>> of a feature while the mouse is over it without selecting it. I
>>>>>> managed
>>>>>> to do this by building a customized control similar to the
>>>>>> SelectFeature
>>>>>> control named HighlightFeature. I shared the code and some people
>>>>>> showed interest in this feature. In fact, it was a good enough
>>>>>> to be
>>>>>> added to trunk but there was a problem : it's too similar to the
>>>>>> SelectFeature control.
>>>>>> My first new option was to modify the SelectFeature control to
>>>>>> be able
>>>>>> to select and highlight. That's what I did, but I hit a wall : I
>>>>>> needed
>>>>>> to add more new events "beforefeaturehighlighted",
>>>>>> "featurehighlighted",
>>>>>> etc. a new array of highlightedFeatures, etc... That also became a
>>>>>> pain because it was yet an other duplication of something already
>>>>>> existant ( similair "select" feature events, an array of selected
>>>>>> features, etc....)
>>>>>> SO, that brings me to this solution, the first one Eric Lemoine
>>>>>> proposed : an array of selectedFeatures and select events for the
>>>>>> control ( without removing the ones of the layer ). Doing that, one
>>>>>> vector layer could have multiple select feature controls that
>>>>>> would know
>>>>>> which feature it has selected, they could all have a different
>>>>>> renderIntent value ( this is already possible ) or their own style.
>>>>>> Then, the user could interact directly with the desired control's
>>>>>> selectedFeatures.
>>>>>> My example : One SelectFeature that select on click, has the
>>>>>> default
>>>>>> render intent "select", on which I register a "featureselected" to
>>>>>> display a form to fill. And one other SelectFeature that select on
>>>>>> hover, has a custom render intent "temporary" to have a different
>>>>>> color
>>>>>> and an event registered to "featureselected" to display a quick
>>>>>> popup of
>>>>>> the infos of the hovered feature.
>>>>>> Even my DeleteFeature control I created a couple of weeks ago could
>>>>>> work by using an other SelectFeature control and using its own
>>>>>> featureSelected array.
>>>>>> I'll make thoses small changes, an example and propose this as an
>>>>>> enhancement. What do you think ?
>>>>>> Regards,
>>>>> Alexandre Dubé
>>>>> Mapgears
>>>>> www.mapgears.com
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/dev
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Dev mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
