[OpenLayers-Dev] reassigning map view question
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Jul 14 04:21:40 EDT 2009
On Monday, July 13, 2009, mikani <gina.m.dang at lmco.com> wrote:
> I'm passing the boundbox as a string from a different function, so I actually
> need to create bound object in order to zoomToExtent.
> Originally I thought it didn't pass the special characters, but it somehow
> revert to even if I hard code the str.
> map.getExtent(): left-bottom=(1.3842008623046875,-0.010192394256591797)
> right-top=(1.4185331376953125,0.010192394256591797)
> Any suggestion?
And:
var bbox = bounds.toBBOX();
bounds = OpenLayers.Bounds.fromString(bbox);
>>> Hi,
>>> I'm trying to reset the map to a current viewport by getting the extent
>>> from
>>> current view, and setting the zoomextent to the previous extent, and it's
>>> not working correctly for me.
>>> Is this a correct way to do so? If not, what do I need to call in order
>>> to
>>> reset the map to previous state?
>>> Sample code:
>>> var boundbox = map.getExtent().toBBOX());
>>> After:
>>> map.zoomToExtent(new OpenLayers.Bounds(boundbox));
>> How about
>> var bounds = map.getExtent();
>> map.zoomToExtent(bounds);
>> Cheers,
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> View this message in context: http://n2.nabble.com/reassigning-map-view-question-tp3250698p3252397.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
Eric Lemoine
More information about the Dev
