[OpenLayers-Dev] DeleteFeature control
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Jul 21 12:22:45 EDT 2009
On Tuesday, July 21, 2009, Alexandre Dube <adube at mapgears.com> wrote:
> Oh and by the way, here's what I did for the Control (attached). Is it ok (too much, i.e. about the use of hasOwnProperty functions) ?
why not using the regular
var i, len, control;
for(i = 0, len = controls.length; i < len; i++) {
control = controls[i];
(the OpenLayers way, which is safer than using for in I guess)
> Thanks,
> Alexandre
> Alexandre Dube wrote:
> Eric Lemoine wrote:
> so, to get to the delete control you've been working on, I see more
> value, in terms of flexibility, in adding "control composition" to the
> control base class.
> I also agree. Originally, the control had a Feature handler instead of a SelectFeature control. Looking at it now, it's too simple to be justified as a new control.
> About the 'controls' property and the act./dea. automatism : that's a good idea, but wouldn't it be good to have a 'handlers' property also and activate/deactivate all handlers as well ? Currently, control has a 'handler' property only. Would it make sense to have 'handlers' added a do the same kind of automatism as the new 'controls' property ?
> Agreed.
> Great.
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
