[OpenLayers-Dev] Error with style.addRule in OL2.7 and IE8 and IE7
mode compatibility
Jean-Daniel JDG. GONON
jdg at geosphere.fr
Mon Jun 8 08:07:38 EDT 2009
Hi all
With OpenLayers 2.7, I have an error in
/OpenLayers2.7/lib/OpenLayers/Renderer/VML.js using IE8 and IE7
compatibility mode.
I tested the 3 patchs on this ticket
http://trac.openlayers.org/ticket/1910 :
With IE8_Generic_CSSPrefix_Selectors.patch and vml.patch
<http://trac.openlayers.org/attachment/ticket/1910/vml.patch> , the
page of the map isn't loaded with errors.
With vml2.patch and IE8 (in IE7, the page of the map isn't loaded with
errors), the map is loaded and all functionalities are OK.
But when I want to select features, the form of the polygon/point select
is drawn with a lag of extents.
And if I want to draw a point or polygon, the form of the polygon/point
isn't drawn.
Is there a solution that is not on internet http://trac.openlayers.org/
Tkanks
JD
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090608/38bd5c47/attachment.html
More information about the Dev
