[OpenLayers-Dev] Google Base Layer and WMS Cover
Felipe Alcacibar
falcacibar at gmail.com
Tue Jun 9 06:06:29 EDT 2009
Hi, i have a Google Base Layer and a WMS cover, y convert my
cartography (WMS cover) to epsg:4326 WCS WGS84 the problem come when i
panTo or zoom, when openlayers draw the map the WMS layer its above
that the place that must be shown, when i deactivate and activate the
layer using the layer switcher, redrawi in the correct place i have
something wrong or it is a bug?
I'm using openlayers 2.7
cheers, take care.
Felipe
/// the JavaScript Source
extent = "-74.65234 -51.01375 -70.45508 -30.37288".split(/[,
for (i=0;i<extent.length;i++) extent[i] = parseFloat(extent[i]);
var mapdim = getElementDimensions($('map'));
myBounds = new OpenLayers.Bounds(
extent[0], extent[1],
extent[2], extent[3]
var zoomAttributes = {
numZoomLevels : 19,
minZoomLevel : 5,
transitionEffect : 'resize'
map = new OpenLayers.Map( 'map', {
numZoomLevels : 19,
minZoomLevel : 5,
maxExtent : myBounds,
restrictedExtent : myBounds,
projection : new OpenLayers.Projection('epsg:4326'),
tileSize : new OpenLayers.Size(600, 600),
buffer : 3,
controls : [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.MousePosition({div : $('map-coords'),
title : 'Coordenadas de la posicion del puntero.'}),
new OpenLayers.Control.NavToolbar(),
new OpenLayers.Control.ZoomBox(),
new OpenLayers.Control.Scale($('map-scale')),
new OpenLayers.Control.ScaleLine()
map.addControl(new OpenLayers.Control.LayerSwitcher());
var ghyb = new OpenLayers.Layer.Google(
"Google Hybrid",
OpenLayers.Util.extend(zoomAttributes, {type: G_HYBRID_MAP})
var gphy = new OpenLayers.Layer.Google(
"Google Physical",
OpenLayers.Util.extend(zoomAttributes, {type: G_PHYSICAL_MAP})
var gmap = new OpenLayers.Layer.Google(
"Google Streets", // the default
OpenLayers.Util.extend(zoomAttributes, {type : null})
var gsat = new OpenLayers.Layer.Google(
"Google Satellite",
OpenLayers.Util.extend(zoomAttributes, {type: G_SATELLITE_MAP})
wmsl = new OpenLayers.Layer.WMS( 'Mapa WMS',
httpBase + "/wms/", {
layers : 'rodales',
format : "image/png; mode=24bit",
alpha : true,
isBaseLayer : false,
map.addLayers([ghyb, gphy, gmap, gsat]);
map.addLayer(wmsl);
map.setCenter(myBounds.getCenterLonLat(), 0);
More information about the Dev
