[OpenLayers-Dev] Fixed Strategy question
Paul Spencer
pspencer at dmsolutions.ca
Fri Jun 19 09:02:43 EDT 2009
Is there any particular reason why the Fixed strategy does not use the
layer filter? I'd like to be able to use it against a WFS and load
all the features but with a filter.
I've tested this in my application using this quick workaround:
var fixed = new OpenLayers.Strategy.Fixed({
load: function(options) {
OpenLayers.Strategy.Fixed.prototype.load.apply(this,
[{filter:this.layer.filter}]);
and it works as I would like. I will add a patch to make Fixed work
like BBOX in applying a filter in the load method unless there is a
reason why it was left out in the first place.
Cheers
Paul
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the Dev
