[OpenLayers-Dev] Topology proposal
Björn Harrtell
bjorn.harrtell at gmail.com
Tue Jun 23 17:49:26 EDT 2009
Since I made the ticket I've done some additional work available in a
new sandbox (just for my own sake to keep track what I'm doing against
2.8 release)
The new stuff is topologyenforcement when adding or removing vertices,
which means that other features intersecting vertices will be removed
and an edge crossing a new vertex will be split so that another vertex
intersects the new one.
OpenLayers stuff added are vertexadded and vertexremoved events to the
Vector layer and an improvement (?) to containsPoint to give info
about which edge is crossing (if it is crossing).
Example is at:
http://dev.openlayers.org/sandbox/bjornharrtell/eventbasedtopology2/examples/topology.html
I'd also like to say that while I'm more or less where I wanted to get
functionally and have no current plans for further developent, new
patches for #2125 aren't my highest priority, partially because I
think the ticket/patch is good enough to discuss the matter of
if/how/when to continue the work somehow.
/Björn
2009/6/11 Björn Harrtell <bjorn.harrtell at gmail.com>:
> I won't argue for the current name, and can see your point so.. we'll
> see what happens :)
> Anyway, I put togheter the current code into a patch against current
> trunk for further discussion which might help you review the source
> (which would be highly appriciated):
> http://trac.openlayers.org/ticket/2125
> /Björn
> On Thu, Jun 11, 2009 at 09:08, Eric Lemoine<eric.lemoine at camptocamp.com> wrote:
>> 2009/6/9 Björn Harrtell <bjorn.harrtell at gmail.com>:
>>> Thanks Eric :)
>>> Details are important, though I would argue that
>>> OpenLayers.TopologyRule is only one char shorter than
>>> OpenLayers.Topology.Rule ;)
>> I'm not trying to save chars here, but to avoid unnecessary deep
>> namespaces. Just a matter of elegance... I'll try to go deeper in your
>> code and come up with more constructive comments ;)
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
More information about the Dev
