[OpenLayers-Dev] WMSCapabilities - properties and handling
different versions
Trond Michelsen
trondmm-openlayers at crusaders.no
Thu Jun 25 17:00:06 EDT 2009
On Thu, Jun 25, 2009 at 01:53:47PM +0200, Andreas Hocevar wrote:
> On Wed, Jun 24, 2009 at 4:03 PM, Trond Michelsen
> <trondmm-openlayers at crusaders.no> wrote:
>> Personally, I'd prefer to use the same structure and property names
>> for 1.1.1 and 1.3.0 objects.
> Definitely. Like we create the same vector features in Format.GML,
> Format.KML, Format.GeoRSS and so on.
Good. I've opened ticket 2151 and submitted a patch that adds parsing
of SRS, BoundingBox, Dimension and Extent for v1.1.1 and v1.1.0. Tests
are included. For some reason, trac won't show my patches, they have
to be downloaded.
I think everything works properly, and that I got the inheritance
rules right. Reviews are welcomed ;)
There's a couple of things I am a bit unsure of, though. The WMS 1.1.1
standard says this about Dimension:
--8<--
Dimension declarations are inherited from parent Layers. Any new
Dimension declarations in the child are added to the list inherited
from the parent. A child shall not redefine a Dimension with the same
name attribute as one that was inherited.
--8<--
I understand this as it is forbidden for a child layer to include
<Dimension name="elevation"> if this tag is present in the parent
layer. However, in the sample capabilities document in Annex A.2 (also
available at http://schemas.opengis.net/wms/1.1.1/capabilities_1_1_1.xml )
there are layers like this (irrelevant tags and layers removed):
<Layer queryable="1">
<Title>Weather Forecast Data</Title>
<Dimension name="time" units="ISO8601" />
<Extent name="time" default="2000-08-22">1999-01-01/2000-08-22/P1D</Extent>
<Layer>
<Name>Pressure</Name>
<Title>Forecast barometric pressure</Title>
<Dimension name="elevation" units="EPSG:5030" />
<Extent name="elevation" default="0" nearestValue="1">0,1000,3000,5000,10000</Extent>
</Layer>
</Layer>
and that confuses me a bit.
Same thing with Extent. Here's what the standard says:
--8<--
Extent declarations are inherited from parent Layers. Any Extent
declarations in the child with the same name attribute as one
inherited from the parent replaces the value declared by the parent. A
Layer shall not declare an Extent unless a Dimension with the same
name has been declared or inherited earlier in the Capabilities XML.
--8<--
Which I take to mean that either the layer itself has to define the
named dimension the Extent uses, or it must have been defined by any
of the layer's ancestors. But again, the example includes a layer that
contradicts this:
<Layer opaque="1" noSubsets="1" fixedWidth="512" fixedHeight="256">
<Name>ozone_image</Name>
<Title>Global ozone distribution (1992)</Title>
<LatLonBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>
<Extent name="time" default="1992">1992</Extent>
</Layer>
There is a parent layer, but that does not define any dimensions. The
dimension is defined by its sibling, however. But, the way I
understand the standard, this isn't good enough, and my patch will
simply ignore the extent for this layer.
I do think it's odd that the sample capabilities document violates the
standard, though, so I'm a little bit confused. v1.1.0 was a lot
vaguer on this subject, and the v1.1.0 sample document is practically
identical to the v1.1.1 document. My best guess is that they decided
to clarify this issue in v1.1.1, and didn't check if this affected the
sample document.
As <Dimension> and <Extent> was merged in v1.3.0, none of these issues
are relevant for that version.
Trond Michelsen
More information about the Dev
