[OpenLayers-Dev] Map broken by openlayers update?
Thomas Wood grand.edgemaster at gmail.com
Sun Jun 28 18:19:02 EDT 2009
The OSM.org provided OpenStreetMap.js has changed. You need to add
/${z}/${x}/${y}.png to the end of your URL parameters in your custom
layer definition.
2009/6/28 Nop <ekkehart at gmx.de>:
> Hi!
> My openlayers-based map has disappeared since friday. A user has
> suggested that there was an update to openlayers.js which I am using.
> Was there such an update on friday?
> What can be the reason if the map was working properly and now is
> showing only a blank canvas and does not even attempt to load tiles?
> The address is topo.geofabrik.de.
> Any ideas on how to fix this?
> thanks
>        Nop
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards,
Thomas Wood
(Edgemaster)
More information about the Dev mailing list
