[OpenLayers-Dev] Openlayers with Mapguide
ehsan ehsan85 at yahoo.com
Tue Jun 30 23:58:22 EDT 2009
I'm using the mapguide 2.0,
for the pink image layer (the layer does not show),i use the tiled map
when i right click and view the image it's show:
Index is out of range.
Exception occurred in method MgMapBase.GetFiniteDisplayScaleAt at line 283
in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\MapLayer/MapBase.cpp
zspitzer wrote:
> You need to dive in and find out what the the error was...
> Which version of mapguide are you using?
> What did the mapguide server error log say?
> try right clicking on a pink tile and view the image
> z
> On Wed, Jul 1, 2009 at 10:47 AM, ehsan<ehsan85 at yahoo.com> wrote:
>> Hi, i need help on getting started openlayer with mapguide..?any link
>> that i
>> can use to learn...i'm still new with mapguide and OpenLayer..
>> i just download the OpenLayers-2.8 and sheboygan.php from the code sample
>> at
>> https://trac.osgeo.org/mapguide/attachment/wiki/CodeSamples/JavaScript/OpenlayersExample/sheboygan.php
>> i try to change map layer defination from the sheboygan.php code, but the
>> layer does not appear, it just came out with pink layer...any body
>> help..?
>> Thanks,
>> ehsan.
>> View this message in context:
>> http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186274.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> Dev mailing list
View this message in context: http://n2.nabble.com/Openlayers-with-Mapguide-tp3186274p3186965.html
More information about the Dev mailing list
