[OpenLayers-Dev] MapGuide patches
Christopher Schmidt crschmidt at metacarta.com
Sun Mar 1 15:49:26 EST 2009
On Sat, Feb 28, 2009 at 10:51:18PM -0800, carls wrote:
> I had tested the patch of #1756. it can work with MapGuide OS 2.0.1.
> Because MapGuide OS 2.1 will be released at April 2 (See Website of MGOS),
> the overlayer for MGOS can't be tested now.
> I hope the final release of OL2.8 could be a bit later than MGOS 2.1.
The important thing that I want someone to confirm is that 1756 won't
*break* the support for overlays that exists for MGOS 2.0/OL 2.7
combination. If that's the case, then the patch needs more work.
Are you confirming that? I understand that this means that the 2.0
behavior will still require things to be synchronous. I see that
kseograf uploaded a patch which should do this, but n one has confirmed
it's the right thing.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
