[OpenLayers-Dev] Able to delete/ move feature and save it without
problems, but upon refreshing the data,
it is the same as before the delete/ move.
Sunder Raj Abbai Naidoo
SunderRajA at sita.co.za
Sun Mar 8 10:57:49 EDT 2009
Good Day Everyone
I am busy working on a project that requires a feature to be added, moved and deleted. The "add feature" functionality works i.e. able to add a feature, save it and upon refresh the feature is displayed. The "move feature" functionality is able to move a feature and save without any bugs, but upon refreshing the data the feature is in the old location. The "delete feature" functionality is able to delete a feature and save without any bugs, but upon refreshing the data the feature is displayed. Below is the coding that I am using. Your help is appreciated.
Definition of WFS
var cities = new OpenLayers.Layer.WFS(
"Cities",
"http://10.128.78.27:8080/geoserver/wfs",
{typename: topp:tasmania_cities'},
{featureNS: http://www.openplans.org/topp',
extractAttributes: true});
cities.style = OpenLayers.Util.applyDefaults({strokeColor: "#0000ff"},
OpenLayers.Feature.Vector.style["default"]);
Defination of Add, Edit, Del, Save.
function deleteFeature(geometry)
this.state = OpenLayers.State.DELETE;
this.layer.removeFeatures(geometry);
this.renderIntent = "select";
var drawPoint = new OpenLayers.Control.DrawFeature(
cities, OpenLayers.Handler.Point,
{displayClass: 'olControlAddFeaturePoint'});
drawPoint.featureAdded = function(feature) {
feature.layer.eraseFeatures([feature]);
// cast to point
feature.geometry = new OpenLayers.Geometry.MultiPoint(feature.geometry);
feature.style.strokeColor = "#0000ff";
feature.state = OpenLayers.State.INSERT;
feature.layer.drawFeature(feature);
var edit = new OpenLayers.Control.ModifyFeature(cities,
{title: "Modify Feature",
displayClass: "olControlModifyFeature"});
var save = new OpenLayers.Control.Button(
{title: "Save Changes",
trigger: OpenLayers.Function.bind(cities.commit, cities),
displayClass: "olControlSaveFeatures"});
var del = new OpenLayers.Control.SelectFeature(cities,
{title: "Delete Feature",
onSelect: deleteFeature,
displayClass: "olControlDeleteFeature"});
Kind Regards,
Specialist: Analyst Programmer
IT Consulting; Solution Delivery
+27 (0)12 470 1584 (Office)
+27 (0)12 470 1456 (Fax)
+27 (0)83 461 3397 (Mobile)
More information about the Dev
