[OpenLayers-Dev] Shape files in openlayers
Guillaume Sueur
no-reply at neogeo-online.net
Wed Mar 11 13:20:37 EDT 2009
http://mapserver.org/utilities/shp2img.html
Jean-Daniel JDG. GONON a écrit :
> Excuses me, but how can I use this command ?
> Thanks
> Jean-Daniel
> -----Message d'origine-----
> De : Guillaume Sueur [mailto:no-reply at neogeo-online.net]
> Envoyé : mercredi 11 mars 2009 17:33
> À : Jean-Daniel JDG. GONON
> Cc : dev at openlayers.org
> Objet : Re: [OpenLayers-Dev] Shape files in openlayers
> Hi,
> Before testing the mapfile in OpenLayers, you should check it on the
> server-side using shp2img and see if a correct output is generated. As
> long that it isn't, no need to aks OpenLayers to display it.
> Regards,
> Guillaume
>> Hi all,
>> I am a newer on using OpenLayers :
>> I want to view data in MapServer (version 2.3.1) using OpenLayers
>> (version 2.7).
>> In my OpenLayers JS file, I call my mapfile (in attachment) with
>> MapServer like this :
>> */var layer1= new OpenLayers.Layer.MapServer( "Audincourt SHP mapserver",/*
>> */"http://localhost/cgi-bin/mapserv.exe", { layers: '', map:
>> 'C:/ms4w/geosphere/client1/Carte16_IA.map'}, {singleTile: true} );/*
>> */map.addLayer(layer1);/*
>> But in the firefox window, only RASTER layer (with .PNG file in DATA) is
>> shown. Others layers aren't displayed.
>> With this URL in firefox :
>> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/geosphere/client1/Carte16_IA.map&mode=map
>> <http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/geosphere/client1/Carte16_IA.map&mode=map>
>> => I see the map I want.
>> Question : why layers (with shape and .ecw files in DATA) are not
>> displayed in my map ?
>> Thank you for answers
>> Jean-Daniel
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev
