[OpenLayers-Dev] Shape files in openlayers
Guillaume Sueur
no-reply at neogeo-online.net
Thu Mar 12 04:24:02 EDT 2009
When using shp2img you are out of the webserver scope. This mean that
you may have to add to your system path some directories which are
declared in the apache environment. Try to add C:\ms4w\Apache\cgi-bin tu
your system path.
But anyway, as it seems that your problems rely mostly on mapserver
installation and configuration, the mapserver-users list would be a much
appropriate place to post your questions.
Regards,
Guillaume
Jean-Daniel JDG. GONON a écrit :
> Hi
> Thank you.
> I have tested "shp2img -m vector_blank.map -o test.png" in cmd.
> But I have an error : "this program can't start because libmap.dll is missing".
> Libmap.dll is existing in C:\ms4w\Apache\cgi-bin and C:\ms4w\Apache\cgi-bin\ignored-libmap\oracle10g , I have tested to replace the first by the second (and restart apache ms4w service), but I always have my error.
> I don't find solution on internet...
> Do you have a solution to help me ?
> Jean-Daniel
> -----Message d'origine-----
> De : Guillaume Sueur [mailto:no-reply at neogeo-online.net]
> Envoyé : mercredi 11 mars 2009 18:21
> À : Jean-Daniel JDG. GONON
> Cc : dev at openlayers.org
> Objet : Re: [OpenLayers-Dev] Shape files in openlayers
> http://mapserver.org/utilities/shp2img.html
>> Excuses me, but how can I use this command ?
>> Thanks
>> Jean-Daniel
>> Envoyé : mercredi 11 mars 2009 17:33
>> Hi,
>> Before testing the mapfile in OpenLayers, you should check it on the
>> server-side using shp2img and see if a correct output is generated. As
>> long that it isn't, no need to aks OpenLayers to display it.
>> Regards,
>> Guillaume
>>> Hi all,
>>> I am a newer on using OpenLayers :
>>> I want to view data in MapServer (version 2.3.1) using OpenLayers
>>> (version 2.7).
>>> In my OpenLayers JS file, I call my mapfile (in attachment) with
>>> MapServer like this :
>>> */var layer1= new OpenLayers.Layer.MapServer( "Audincourt SHP mapserver",/*
>>> */"http://localhost/cgi-bin/mapserv.exe", { layers: '', map:
>>> 'C:/ms4w/geosphere/client1/Carte16_IA.map'}, {singleTile: true} );/*
>>> */map.addLayer(layer1);/*
>>> But in the firefox window, only RASTER layer (with .PNG file in DATA) is
>>> shown. Others layers aren't displayed.
>>> With this URL in firefox :
>>> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/geosphere/client1/Carte16_IA.map&mode=map
>>> <http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/geosphere/client1/Carte16_IA.map&mode=map>
>>> => I see the map I want.
>>> Question : why layers (with shape and .ecw files in DATA) are not
>>> displayed in my map ?
>>> Thank you for answers
>>> Jean-Daniel
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
> Dev mailing list
More information about the Dev
