[OpenLayers-Dev] this.callbacks is undefined error
bartvde at osgis.nl
bartvde at osgis.nl
Thu Mar 12 07:46:29 EDT 2009
first of all, please don't cross-post to dev and users if it is not
necessary.
Maybe you can check out the following for pointers:
http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/lib/OpenLayers/Control/FeatureInfo.js
http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/examples/featureinfo-control.html
Best regards,
Bart
> Good Day Everyone
> I want to make use of the GetFeatureInfo functionality, but I want to do
> so by clicking a button on the map panel. Below is the coding that I am
> using. I click on the button and when I click on a feature point I get
> the following error displayed below in firebug. FYI, I am using
> OpenLayers 2.7. Can someone please help me with this?
> ERROR:
> OpenLayers.js (line 662)
> SOURCE CODE:
> var featureInfo;
> // build the featureInfo (aka query tool/button)
> featureInfo = new OpenLayers.Control(
> {title: "Query map features",
> displayClass: "olControlFeatureInfo"});
> // register events to the featureInfo tool
> featureInfo.events.register("activate", featureInfo, function() {
> toggleQueryMode(); });
> featureInfo.events.register("deactivate", featureInfo, function() {
> panel.addControls([featureInfo]);
> // support GetFeatureInfo
> queryEventHandler = new OpenLayers.Handler.Click({'map': map, 'click':
> function(e) { doGetFeatureInfo(e); } });
> function toggleQueryMode() {
> if(featureInfo.active) {
> queryEventHandler.activate();
> } else {
> queryEventHandler.deactivate();
> function doGetFeatureInfo(e) {
> document.getElementById('nodelist').innerHTML = "Loading... please
> wait...";
> var url = map.layers[0].getFullRequestString(
> {REQUEST: "GetFeatureInfo",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: map.getExtent().toBBOX(),
> X: e.xy.x,
> Y: e.xy.y,
> INFO_FORMAT: 'text/html',
> QUERY_LAYERS: map.layers[0].params.LAYERS,
> FEATURE_COUNT: 50,
> WIDTH: map.size.w,
> HEIGHT: map.size.h},
> "http://10.128.78.27:8080/geoserver/gwc/service/wms");
> OpenLayers.loadURL(url, '', this, setHTML, setHTML);
> OpenLayers.Event.stop(e);
> Thanks
> Raj.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
