[OpenLayers-Dev] displayProjection in IE
Mike Adair
madair at dmsolutions.ca
Mon Mar 23 14:04:35 EDT 2009
You probably want to use proj4js-compressed.js rather than just
proj4js.js. The combined/compressed versions of proj4js include all
projection class code in one file so those files don't have to be loaded
dynamically. Other than that, I can't see anything wrong with the
proj4js setup.
Mike
toni hernández wrote:
> Hi,
> it's been a while since I last wrote this but I got the last svn
> version and still I can't reproject in IE.
> I need to reproject to UTM so I can calculate the coordinates of one
> point from another base point in one known direction to a distance.
> For instance: I need to know the coordinates of a X point that is 10
> metres from point A (coordinates known) following 45 degrees north.
> I know I can do that with UTM coordinates just with some basic
> trigonometry. Is it possible with lat and lon coordinates?
> And going back to the reprojection issue these are the include files:
> <script src="../proj4js/lib/proj4js.js"></script>
> <script src="../proj4js/lib/defs/EPSG23031.js"></script>
> and this is the EPSG23031.js file
> Proj4js.defs["EPSG:23031"] = "+proj=utm +zone=31 +ellps=intl +units=m
> +no_defs ";
> Am I still missing something.
> On Tue, Mar 10, 2009 at 3:08 PM, Mike Adair <madair at dmsolutions.ca
> <mailto:madair at dmsolutions.ca>> wrote:
> There was an IE bug in Proj4js that got fixed a few weeks ago. I
> would first suggest to make sure you are using the SVN version, (I
> really should prepare another release candidate for Proj4js).
> Mike
> hi,
> I need to reproject a map with proj4js from 4326 to 23030 and
> display the mouseposition in 23030.
> All the proj4js files with my projections are included (as I
> read somewhere) but still IE is not reprojecting.
> FF works great.
> What's that I am missing?
> Cheers.
> <script src="../proj4js/lib/defs/EPSG23029.js"></script>
> <script src="../proj4js/lib/defs/EPSG23030.js"></script>
> Dev mailing list
> Dev at openlayers.org <mailto:Dev at openlayers.org>
> http://openlayers.org/mailman/listinfo/dev
> Michael Adair
> Senior Software Architect
> DM Solutions Group Inc.
> Office: (613) 565-5056 x26
> madair at dmsolutions.ca <mailto:madair at dmsolutions.ca>
> http://www.dmsolutions.ca
> http://research.dmsolutions.ca
Michael Adair
More information about the Dev
