[OpenLayers-Dev] lines with only two vertexs
toni hernández
tonidelacalle at gmail.com
Wed Mar 25 04:23:53 EDT 2009
Hi all,
I need to draw lines with only two vertexs so when the second vertex is
added the draing must end.
I've done it so far creating a new handler.path where I control the length
of the geometry components. When is bigger than 2 I run the finalize
function so it ends.
That works fine but I think there must be a better way of doing it?
I have also tried registering the sketchmodified event of the control from
the main html page.
The issue here is that I do not know how to deactivate the drawing control
without throwing and error. (feature is null, on Vector.js (line 617, in
drawFeature function)
any ideas?
the code.
//DRAWING CONTROLS
drawControls = {
point: new OpenLayers.Control.DrawFeature(pointLayer,
OpenLayers.Handler.Point),
line: new OpenLayers.Control.DrawFeature(lineLayer,
OpenLayers.Handler.Path, options),
polygon: new OpenLayers.Control.DrawFeature(polygonLayer,
OpenLayers.Handler.Polygon, options)
for(var key in drawControls) {
map.addControl(drawControls[key]);
//REGISTERING
drawControls.line.layer.events.on({
'sketchmodified': report
function report(param)
if (param.feature.components.length>2)
drawControls.line.handler.finalize();
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090325/2ad0535b/attachment.html
More information about the Dev
