[OpenLayers-Dev] singleTile and Google Maps error
Christopher Schmidt
crschmidt at metacarta.com
Mon Mar 30 18:17:48 EDT 2009
On Mon, Mar 30, 2009 at 02:56:30PM -0400, Julien-Samuel Lacroix wrote:
> Hi,
> I have a problem with a singleTile WMS layer above Google Maps. I wanted
> to check to see if anyone has seen it before or if there's a already a
> ticket that I missed before investigating further.
> The problem is when combining a google layer with a singleTile overlay,
> when looking at the whole world, the overlay is displayed on the
> right-hand side of the map and not in the current view. Sometimes it's
> even way off the map.
> From what I understood, OL tries to place the layer at the right place,
> but the top-right coordinates it gets go behond the dateline and get
> shifted to the right. Here's an example to reproduce:
Yes, this is a problem. No, I don't have a suggested solution (other
than 'use tiles').
-- Chris
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <script src="/openlayers/openlayers/lib/OpenLayers.js"></script>
> <script
> src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAACCFvpt30gpRs1CNZ1gCc_RTBfUk9TZrBRaIteybtnU2KziHEpRQjbtlKJwRisyazNeb0Lj9_OfGlMA'></script>
> <script type="text/javascript">
> var map, options;
> function init()
> var maxBounds = new OpenLayers.Bounds(-20000000, -8000000,
> 20000000, 15000000);
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 19,
> minScale: 120000000,
> maxExtent: maxBounds
> map = new OpenLayers.Map('map', options);
> // create Google Mercator layers
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets",
> {'sphericalMercator': true}
> // create WMS layer
> var wms = new OpenLayers.Layer.WMS(
> "World Map",
> "http://labs.metacarta.com/wms/vmap0",
> {'layers': 'basic'},
> 'opacity': 0.7,
> 'isBaseLayer': false,singleTile:true
> map.addLayers([gmap, wms]);
> map.zoomToMaxExtent();
> </script>
> </head>
> <body onload="init()">
> <div id="map" style="width:550px;height:300px"/>
> </body>
> </html>
> Mapgears
> http://www.mapgears.com/
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev
