[OpenLayers-Dev] Layer.GML how to access the XML?
Christopher Schmidt
crschmidt at metacarta.com
Mon May 4 15:37:42 EDT 2009
On Mon, May 04, 2009 at 11:46:34AM -0700, gwales wrote:
> I could see from firebug that features[0].geometry was possibly the answer
> to my issue but on trying to access features[0] i get 'undefined' and if try
> to go deeper than that I get an error.
> Code is:
> // Add the Layer with GPX Track
> var lgpx = new OpenLayers.Layer.GML("MMGPX",
> "TrackLogs/MM_TL_1.gpx", {
> format: OpenLayers.Format.GPX,
> style: {strokeColor: "blue", strokeWidth: 5, strokeOpacity:
> 0.5},
> projection: new OpenLayers.Projection("EPSG:4326")
> map.addLayer(lgpx);
> console.log(lgpx);
> var featGeom=lgpx.features[0].geometry;
> console.log(featGeom);
> I am unsure what I am doing incorrectly in trying to access that linestring?
Data is loaded asynchronously. use: layer.events.register("loadend",
layer, function() {
console.log(this.features[0].geometry.components.length); });
Christopher Schmidt
MetaCarta
More information about the Dev
