[OpenLayers-Dev] tests on 2.8 branch
Eric Lemoine eric.lemoine at camptocamp.com
Thu May 7 14:59:55 EDT 2009
On Thursday, May 7, 2009, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi list,
> I've just run a few tests (up until Format) on the 2.8 branch in FF
> 3.0.10 on Windows XP, but some of them fail for me, see:
> http://pastebin.com/m93dd28f
> Is this something specific to my setup or are others experiencing
> failures as well?
> Most notably:
> -Element
> -KeyboardDefaults
> -OverviewMap
IIRC those may fail for timing reasons. If you increase the delay in
the test framework confit they will probably pass.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
