[OpenLayers-Dev] WMSCapabilities and SRS
Luis Belloch
lbelloch at prodevelop.es
Fri May 22 04:27:29 EDT 2009
We’re developing an application using Mapfish and OpenLayers. We have a
control that let you pick a WMS server, select some layers and add them to
the current map. As OpenLayers won’t render layers in different projections,
the control should prevent the user to add it.
The current WMS parser for GetCapabilities is missing the SRS for each
layer, so we patched the parser to add it. Is there any way to get the
service (not layer) projections? Anyone working on this?
You can grab the patch from
https://svn.prodevelop.es/public/labs/users/lbelloch/openlayers/
Thanks!
Luis Belloch | Prodevelop
luisbelloch at prodevelop es
View this message in context: http://n2.nabble.com/WMSCapabilities-and-SRS-tp2956248p2956248.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
