[OpenLayers-Dev] Select all features in a layer
Josh S.
jstreufe at utk.edu
Sat May 23 20:05:42 EDT 2009
I would like to draw several ploygons on a map then save the entire vector
layer out as a KML file. I have hacked away at the code for the Vector
Formats example (http://openlayers.org/dev/examples/vector-formats.html), it
will do it for individual polygons but I can't seem to figure a way to do
the entire layer and the force the serialize function to run. Any help (and
Code) would be greatly appreciated!
Here's what I've got so far...
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Josh's Openlayers Project</title>
<style type="text/css">
input, select, textarea {
font: 0.9em Verdana, Arial, sans-serif;
#map {
width: 512px;
height: 225px;
border: 1px solid #ccc;
#input {
width: 512px;
#userkml {
font-size: 0.85em;
margin: 1em 0 1em 0;
width: 100%;
height: 10em;
#info {
position: relative;
padding: 2em 0;
margin-left: 540px;
#output {
font-size: 0.8em;
width: 100%;
p {
margin: 0;
padding: 0.75em 0 0.75em 0;
</style>
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
<script type="text/javascript">
var map, vectors, formats;
var proj = "EPSG:4326";
alert(proj);
var filetype = "kml";
alert(filetype);
function updateFormats() {
var in_options = {
'internalProjection': map.baseLayer.projection,
'externalProjection': new
OpenLayers.Projection(OpenLayers.Util.getElement("proj"))
var out_options = {
formats = {
'in': {
kml: new OpenLayers.Format.KML(in_options)
'out': {
kml: new OpenLayers.Format.KML(out_options)
function init(){
map = new OpenLayers.Map('map');
var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
vectors = new OpenLayers.Layer.Vector("Vector Layer");
map.addLayers([wms, vectors]);
map.addControl(new OpenLayers.Control.MousePosition());
map.addControl(new OpenLayers.Control.EditingToolbar(vectors));
var options = {
multiple: true,
onSelect: serialize
var select = new OpenLayers.Control.SelectFeature(vectors,
options);
map.addControl(select);
select.activate();
updateFormats();
map.setCenter(new OpenLayers.LonLat(0, 0), 1);
function serialize(feature) {
var type = filetype;
var shape = feature.geometry;
var name = feature.attributes['Placemark','name'];
alert(name);
alert(shape);
var str = formats['out'][type].write(feature);
// not a good idea in general, just for this demo
str = str.replace(/,/g, ', ');
document.getElementById('output').value = str;
/*function clearMap() {
var erase = new OpenLayers.Control.removeFeatures(features);
map.addControl(erase);
erase.activate();
function deserialize() {
var element = document.getElementById('userkml');
var features = formats['in'][type].read(element.value);
var bounds;
if(features) {
if(features.constructor != Array) {
features = [features];
for(var i=0; i<features.length; ++i) {
if (!bounds) {
bounds = features[i].geometry.getBounds();
} else {
bounds.extend(features[i].geometry.getBounds());
vectors.addFeatures(features);
map.zoomToExtent(bounds);
var plural = (features.length > 1) ? 's' : '';
element.value = features.length + ' feature' + plural + '
added'
} else {
element.value = 'Bad input ' + type;
// preload images
(function() {
var roots = ["draw_point", "draw_line", "draw_polygon", "pan"];
var onImages = [];
var offImages = [];
for(var i=0; i<roots.length; ++i) {
onImages[i] = new Image();
onImages[i].src = "../images/" + roots[i] + "_on.png";
offImages[i] = new Image();
offImages[i].src = "../images/" + roots[i] + "_on.png";
</script>
</head>
<body onload="init()">
<div id="map"></div>
<div id="input">
<p>Draw...</p>
<br />
<textarea id="output"></textarea>
<br />
<textarea id="userkml">Paste Your KML Here...</textarea>
<br />
<input type="button" value="Add Your KML"
onclick="deserialize();" />
<!--<input type="button" value="Clear Map" onclick="clearMap();" />-->
</div>
</body>
</html>
-Josh
View this message in context: http://n2.nabble.com/Select-all-features-in-a-layer-tp2963573p2963573.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
