[OpenLayers-Dev] RC5 prop
Christopher Schmidt crschmidt at metacarta.com
Sat May 30 16:54:28 EDT 2009
On Sat, May 30, 2009 at 10:28:50PM +0200, Eric Lemoine wrote:
> On Friday, May 29, 2009, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > So, Pierre and Andreas worked out:
> >   http://trac.openlayers.org/ticket/1797#comment:22
> > To likely be a Google API change.  As I understand it, this:
> >     * CHanged something that worked when we fixed it, to something that
> >       didn't
> >     * Was a change due to a GMaps API change
> >     * Was something that we put a lot of effort into fixing
> >     * Affects MapFish/GeoExt (and probably other JS Frameworks with
> >     * flexible map sizes)
> > As a result, I think it's worth including in 2.8: It was worth it the
> > first time, it's still worth it this time (even though we aren't
> > responsible for the regression, we've still got to deal with it.)
> > IF this ticket doesn't affect people (I think it does -- i just emailed
> > the geoext list about it, and pierre bumped into it, after all) then we
> > can bump it, but otherwise, it's worth another RC.
> > So, if anyone else agrees with me -- and I'd especially like to hear
> > from GeoExt or MapFish people who can confirm that this is actually an
> > issue, and is now fixed -- then I say I roll an RC5 this afternoon.
> It indeed affects GeoExt - Google layers within a map panel do not
> display. I'll test Andreas' latest patch on Tuesday (said Monday in
> the ticket but realized Monday is off for me) and will report back in
> the ticket.
Well, a GeoExt user was able to confirm that 2.8-rc4 did not work, and
using Google.js from trunk did, so I'm happy enough saying that this has
been tested with GeoExt for the problem reported.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
