[OpenLayers-Dev] RC5 prop
Tim Schaub
tschaub at opengeo.org
Sun May 31 02:14:47 EDT 2009
Hey-
Christopher Schmidt wrote:
> So, Pierre and Andreas worked out:
> http://trac.openlayers.org/ticket/1797#comment:22
> To likely be a Google API change. As I understand it, this:
> * CHanged something that worked when we fixed it, to something that
> didn't
> * Was a change due to a GMaps API change
> * Was something that we put a lot of effort into fixing
> * Affects MapFish/GeoExt (and probably other JS Frameworks with
> * flexible map sizes)
> As a result, I think it's worth including in 2.8: It was worth it the
> first time, it's still worth it this time (even though we aren't
> responsible for the regression, we've still got to deal with it.)
> IF this ticket doesn't affect people (I think it does -- i just emailed
> the geoext list about it, and pierre bumped into it, after all) then we
> can bump it, but otherwise, it's worth another RC.
> So, if anyone else agrees with me -- and I'd especially like to hear
> from GeoExt or MapFish people who can confirm that this is actually an
> issue, and is now fixed -- then I say I roll an RC5 this afternoon.
Looks like the response I intended to send on Friday was swallowed
somewhere along the way. Anyway, thanks for kicking out another RC when
you get the chance.
Tim
> Best REgards,
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
