[OpenLayers-Dev] OpenLayers & SVG Web
Christopher Schmidt crschmidt at metacarta.com
Mon Nov 30 07:38:20 EST 2009
On Fri, Nov 27, 2009 at 03:06:24PM +0100, Jonathan Pasquier wrote:
> Hello,
> I have been doing some experiment with OpenLayers recently, and especially
> with the Vector feature.
> After seeing the recent announcement of a new release of SVG
> web<http://code.google.com/p/svgweb/>,
> a js library which aims to provide suport for SVG to all browser,
> I have decided to try to integrate it with OpenLayers so I could use my
> beloved SVG under any browser (including IE!!!)
OpenLayers already has support for vectors in all browsers, including IE.
No use of an external library is neccesary.
What were you trying to accomplish using svgweb?
-- Chris
> After a couple of days fighting against the DOM, javascript and flash, I
> have finally manage to get something usable.
> It still in alpha stage, but if you want you can give it a try.
> Source and examples are available here:
> http://www.bordel-de-nerd.net/olsvgweb/
> I have only tested it under Firefox 3.5 and IE 8, but it should work with
> other browsers as well.
> Any comment or suggestion will be welcome!
> Regards,
> Jonathan
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
