[OpenLayers-Dev] general questions regarding the process of patches for new/enhanced functionality
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Sat Oct 3 06:21:46 EDT 2009
Hi Marc,
welcome to the community, you're almost there (opening a ticket with a
patch is the right way), a few pointers:
-it is wise to set the state of your ticket to review, also if you want
it to get attention, make sure the milestone is the next possible
release (right now 2.9)
-a patch with a testcase is better than a patch without a testcase, so
if you could look into how to write a testcase that would be great
-a patch should ideally work against trunk
Best regards,
Bart
Marc Jansen wrote:
> Hi devs,
> I recently opened two tickets ([1], [2]) for new / enhanced
> functionality of OpenLayers components. Both of them have (more or less
> trivial) patches attached to provide the actual functionality.
> I would love to have a short note/review about the code in question by
> someone with deeper insights in the project.
> I am not quite sure if I did everything the "OpenLayers-Way". Is the
> process of opening a ticket and submitting a patch the desired way?
> Should I have started a discussion on this list prior to opening the
> ticket? Please help me since I would love to participate in the project.
> BTW: I have not handed in a CLA up until now. Maybe we can fix this in
> Sydney, as I guess many from the project will meet up there.
> Regards,
> Marc
> [1] http://trac.openlayers.org/ticket/2266
> [2] http://trac.openlayers.org/ticket/2288
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
More information about the Dev mailing list
