[OpenLayers-Dev] ImgPath and theme
Jochen Topf jochen at remote.org
Sun Oct 4 12:25:55 EDT 2009
Hi!
If you want to create a different theme for OpenLayers there are two things
you need to handle:
* Some images are found through the setting in OpenLayers.ImgPath
* Some images and styles are found through the theme mechanism (setting theme
  option on map object)
Is there a reason those cases are handled differently? Wouldn't it make
sense to put all the images in one directory and find them through the
theme mechanism?
Jochen
Jochen Topf  jochen at remote.org  http://www.remote.org/jochen/  +49-721-388298
More information about the Dev mailing list
