[OpenLayers-Dev] general questions regarding the process of patches for new/enhanced functionality
Tim Schaub tschaub at opengeo.org
Tue Oct 6 14:49:50 EDT 2009
Thanks for the excellent contribution Marc.
http://trac.openlayers.org/changeset/9720
I think it would be worth making eliminateDuplicates true by default
(and maybe changing it to simply "duplicates" and making it false).
Would anyone object?
Tim
Marc Jansen wrote:
> Hi Bart,
> thanks for the warm welcome :-)
> Bart van den Eijnden (OSGIS) schrieb:
>> Hi Marc,
>> welcome to the community, you're almost there (opening a ticket with a
>> patch is the right way), a few pointers:
>> -it is wise to set the state of your ticket to review, also if you
>> want it to get attention, make sure the milestone is the next possible
>> release (right now 2.9)
> OK. I'll change that
>> -a patch with a testcase is better than a patch without a testcase, so
>> if you could look into how to write a testcase that would be great
> OK. I will try to do that as well.
>> -a patch should ideally work against trunk
> Both patches work against the latest version of the trunk... or am I
> misinterpreing something,
> Regards,
> Marc
>> Best regards,
>> Bart
>> Marc Jansen wrote:
>>> Hi devs,
>>> I recently opened two tickets ([1], [2]) for new / enhanced
>>> functionality of OpenLayers components. Both of them have (more or
>>> less trivial) patches attached to provide the actual functionality.
>>> I would love to have a short note/review about the code in question
>>> by someone with deeper insights in the project.
>>> I am not quite sure if I did everything the "OpenLayers-Way". Is the
>>> process of opening a ticket and submitting a patch the desired way?
>>> Should I have started a discussion on this list prior to opening the
>>> ticket? Please help me since I would love to participate in the project.
>>> BTW: I have not handed in a CLA up until now. Maybe we can fix this
>>> in Sydney, as I guess many from the project will meet up there.
>>> Regards,
>>> Marc
>>> [1] http://trac.openlayers.org/ticket/2266
>>> [2] http://trac.openlayers.org/ticket/2288
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
