[OpenLayers-Dev] Multi Layer Select
Eric Lemoine eric.lemoine at camptocamp.com
Tue Oct 6 15:46:47 EDT 2009
On Mon, Oct 5, 2009 at 2:47 PM, Richard Ive <richard at xanox.net> wrote:
> Hi All,
> I'm trying to figure out a solution to a problem, but unfortunately I'm not
> having much luck so I was wondering if anyone had any ideas.
> I have two Vector layers that each have their own features. I need all
> features to be selectable, but each layer should have it's own select rules
> eg:
> Layer1 = multi-select: false
> Layer2 = multi-select: true
> The example below means Layer1 & Layer2 have multi-select, however that's
> not what I need.
To my knowledge OpenLayers doesn't currently provide what you need.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
