[OpenLayers-Dev] duplicate attribution
Tim Schaub tschaub at opengeo.org
Thu Oct 8 12:06:25 EDT 2009
Hey-
Marc Jansen wrote:
> Hi Tim,
> thanks for the review. Renaming seems reasonable, I guess there is no
> wrong or right.
> As for the default: I chose not to break the behaviour of the control
> when being called without the parameter "eliminateDuplicates" set. On
> the other hand: I can hardly guess of any situation where you wanted
> duplicate atttribution texts.
Yeah, I would suggest that it is a bug to show the same attribution
twice.  In that light, changing the behavior would be fixing something
instead of breaking something.
Anybody else think that displaying the same attribution text multiple
times makes sense?
I'm guessing there is not a strong opinion one way or another.  I do
like the idea that at some point we can streamline the API, instead of
continually adding to it (particularly in cases where we are adding
things to work around somewhat odd behavior).
http://trac.openlayers.org/ticket/2300
Tim
> Just my two cents,
> Regards,
> Marc
> Tim Schaub schrieb:
>> Thanks for the excellent contribution Marc.
>> http://trac.openlayers.org/changeset/9720
>> I think it would be worth making eliminateDuplicates true by default
>> (and maybe changing it to simply "duplicates" and making it false).
>> Would anyone object?
>> Tim
>> Marc Jansen wrote:
>>> Hi Bart,
>>> thanks for the warm welcome :-)
>>> Bart van den Eijnden (OSGIS) schrieb:
>>>> Hi Marc,
>>>> welcome to the community, you're almost there (opening a ticket with
>>>> a patch is the right way), a few pointers:
>>>> -it is wise to set the state of your ticket to review, also if you
>>>> want it to get attention, make sure the milestone is the next
>>>> possible release (right now 2.9)
>>> OK. I'll change that
>>>> -a patch with a testcase is better than a patch without a testcase,
>>>> so if you could look into how to write a testcase that would be great
>>> OK. I will try to do that as well.
>>>> -a patch should ideally work against trunk
>>> Both patches work against the latest version of the trunk... or am I
>>> misinterpreing something,
>>> Regards,
>>> Marc
>>>> Best regards,
>>>> Bart
>>>> Marc Jansen wrote:
>>>>> Hi devs,
>>>>> I recently opened two tickets ([1], [2]) for new / enhanced
>>>>> functionality of OpenLayers components. Both of them have (more or
>>>>> less trivial) patches attached to provide the actual functionality.
>>>>> I would love to have a short note/review about the code in question
>>>>> by someone with deeper insights in the project.
>>>>> I am not quite sure if I did everything the "OpenLayers-Way". Is
>>>>> the process of opening a ticket and submitting a patch the desired
>>>>> way? Should I have started a discussion on this list prior to
>>>>> opening the ticket? Please help me since I would love to
>>>>> participate in the project.
>>>>> BTW: I have not handed in a CLA up until now. Maybe we can fix this
>>>>> in Sydney, as I guess many from the project will meet up there.
>>>>> Regards,
>>>>> Marc
>>>>> [1] http://trac.openlayers.org/ticket/2266
>>>>> [2] http://trac.openlayers.org/ticket/2288
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/dev
>>> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
